Coding I/O Module
abhi_123
Coding I/O Module
Post by abhi_123 »
Hi,
As suggested i am planning to add one in my kitty.I am planning to use water flow sensors to regulate the flow of water into my skimmer,GFO,Carbon,Chiller etc also to check any overflow occurs.
Any idea how to code it & will it be able to fulfill my needs?
Re: Coding I/O Module
abhi_123
Post by abhi_123 »
Can we use it to control the flow on clock to decrease & increase the flow on the basis of time.
Do you have a pump with controllable flow?
abhi_123
Post by abhi_123 »
Ok. can we have flow reading on portal also?
Yes, you can use a custom variable to have the flow readings on the portal
