Hi,
As suggested i am planning to add one in my kitty.I am planning to use water flow sensors to regulate the flow of water into my skimmer,GFO,Carbon,Chiller etc also to check any overflow occurs.
Any idea how to code it & will it be able to fulfill my needs?
Coding I/O Module
abhi_123
abhi_123
Re: Coding I/O Module
Can we use it to control the flow on clock to decrease & increase the flow on the basis of time.
abhi_123
Yes, you can use a custom variable to have the flow readings on the portal
