problem whit wifi
petruzzelli
problem whit wifi
hi boy i have a big problem whit wifi
im sure i have configurated god...
the probem is
if i made the ping i have this
domenicos-iMac:~ domenico$ ping 192.168.0.103
PING 192.168.0.103 (192.168.0.103): 56 data bytes
64 bytes from 192.168.0.103: icmp_seq=0 ttl=255 time=3.061 ms
64 bytes from 192.168.0.103: icmp_seq=1 ttl=255 time=2.281 ms
64 bytes from 192.168.0.103: icmp_seq=2 ttl=255 time=2.238 ms
64 bytes from 192.168.0.103: icmp_seq=3 ttl=255 time=87.573 ms.......
i have this configuration on wifi
get i
IF=UP
DHCP=OFF
IP=192.168.0.103:2000
NM=255.255.255.0
GW=192.168.0.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21>
<2.21> get w
SSID=bombara
Chan=11
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=7972mimmo
<2.21>
my router have this configuration
DHCP Server : enabled
ESSID : bombara
Channel : 11
Security : WPA pre-shared key
Encryption : WPA pre-shared key
WPA Type : WPA2(AES)
Pre-shared Key Type : passphrase
Pre-shared Key : 7972mimmo
on the wifi i have slow blink green led, but if i want open the page whit 192.168.0.103:2000
i have error
where is the solution?
the probem is
get i
IF=UP
DHCP=OFF
NM=255.255.255.0
GW=192.168.0.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21>
<2.21> get w
SSID=bombara
Chan=11
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
<2.21>
ESSID : bombara
Channel : 11
i have error
dmolton
Re: problem whit wifi
What's the error?
Maybe it's a firewall issue?
petruzzelli
i dont have firewalldmolton wrote:What's the error?
the problem is the wifi dont have comunication
the led is ok (for it the connection is ok)
when i made the ping i have comunication but 3 poket is ok and lose 1, the router and the wifi module are in the same room.
but if i open the internet page whit this address 192.168.0.103:2000 have the error comunication
if i open the RAclient2.2 and i go to setting where is possible open the service dash in the spase where is possible learn the ip ad the port i dont have the possibility for put it and they are empty
- Contact:
It could be a network issue, not for sure though.
I had to enable the connection timeout on my wifi for me to communicate with my controller. If I did not, one connection would stay open and I could never communicate.
Did you follow the instruction in the manual?
Were you able to see data in Tera Term coming from controller?
petruzzelli
hi roberto
i have use the tera and when i make the connection whit com it is comunicate and the same when i use telnet i have the possibility go inside for configuration whit $$$.
i have made hard reset and i have used the dave software for configuration but i have the same problem.
i open the pag whit 192.168.xx:2000 and i have white page.... if i disconnect to wifi module to reefangel and i open the same page i have the ie error (same time for responding ecc ecc) for this im sure the wifi module have god parametry and have connection whit my router
What I was asking is the little communication code in the manual.
Anyway, here it is:
Upload to RA and then open Tera Term on 192.168.x.x port 2000.
Do you see anything?
Anyway, here it is:
#include <EEPROM.h>
#include <NokiaLCD.h>
ReefAngel.Init();
ReefAngel.LCD.DrawText(200,36,10,10,"Wifi Test");
ReefAngel.Refresh();
Serial.print("Current Water Temperature is ");
Serial.println(ReefAngel.Params.Temp1);
delay(1000);
}Do you see anything?
petruzzelli
ok roberto i have
Current Water Temperature is 811
It's the same procedure explained in the manual.
http://www.reefangel.com/files/Reef%20A ... 20v1.3.pdf
Upload the code, attach the wifi and open tera term.
petruzzelli
okrimai wrote:It's the same procedure explained in the manual.
but now i have problem whit sketch too big
The code above does not exceed memory.
Don't add it to your own code.
Just use it as is.
You may need to convert to standard libraries if you are getting compile errors: http://forum.reefangel.com/viewtopic.php?f=8&t=2
Just use it as is.
petruzzelli
1) i know i dont att itrimai wrote:The code above does not exceed memory.
Just use it as is.
2) i made http://forum.reefangel.com/viewtopic.php?f=8&t=2
but
Binary sketch size: 34512 bytes (of a 30720 byte maximum)
it is my pde
// Autogenerated file by RAGen (v1.0.4.92), (07/27/2011 00:09)
// RA_072711_0009.pde
#define DisplayImages
#define DosingPumpIntervalSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardLights(Port3);
ReefAngel.DosingPumpRepeat1(Port4);
ReefAngel.DosingPumpRepeat2(Port5);
ReefAngel.StandardFan(Port6);
Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
Here is what you need to do:
1. Make sure you close Arduino IDE.
2. Open the file ReefAngel_Features.h located at "Documents\Arduino\libraries\ReefAngel_Features"
3. Change the contents to this:
4. Save the file
5. Open Arduino IDE
6. Upload your PDE file again.
#define VersionMenu
#define wifi
5. Open Arduino IDE
petruzzelli
sorry change in whit mode' i delete and?rimai wrote:Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
3. Change the contents to this:4. Save the fileCode: Select all
#define VersionMenu #define wifi
5. Open Arduino IDE
petruzzelli
sorryrimai wrote:Can you please rephrase? I did not understand.
what i do? i opene the features.h and?
Just change the contents.
Delete everything and place just these 2 lines:
#define VersionMenu
#define wifi
petruzzelli
ok robertorimai wrote:Just change the contents.
Delete everything and place just these 2 lines:Code: Select all
sorry
i have 2 street
the first
settig reefangel whit this software
1) ReefAngelInstaller.exe
2)RAGen-v104-v08516 Installer.exe
second street
1) download arduino 0.22 software on www.arduino.cc
2) download libraries Version 0.8.3.11
3) download curtbinder-ReefAngel-v0.8.5.16-0-ge9a7435
4) RAGen-v104-v08516 Installer.exe
whit ragen i made memory pde and ra pde
if i use this file whit the first street i have sketch too big, if i use the second street it is ok but i dond have comunication whit wifi
why?
Use 1st option.
After you install ReefAngelInstaller and RAGen, you have to one of these 2:
1. Edit the file ReefAngel_Features.h with just the following:
The file has to be edited after you generate your PDE. Everytime you generate a PDE file, RAGen will overwrite whatever change you've made to the file.
2. just uncheck everything from the RAGen when generating the file, except wifi.
You are picking too many choices of RAGen.
#define VersionMenu
#define wifiYou are picking too many choices of RAGen.
petruzzelli
ok tnx
now is all ok
now is all ok
