problem whit wifi
petruzzelli
problem whit wifi
Post by petruzzelli »
hi boy i have a big problem whit wifi
im sure i have configurated god...
the probem is
if i made the ping i have this
domenicos-iMac:~ domenico$ ping 192.168.0.103
PING 192.168.0.103 (192.168.0.103): 56 data bytes
64 bytes from 192.168.0.103: icmp_seq=0 ttl=255 time=3.061 ms
64 bytes from 192.168.0.103: icmp_seq=1 ttl=255 time=2.281 ms
64 bytes from 192.168.0.103: icmp_seq=2 ttl=255 time=2.238 ms
64 bytes from 192.168.0.103: icmp_seq=3 ttl=255 time=87.573 ms.......
i have this configuration on wifi
get i
IF=UP
DHCP=OFF
IP=192.168.0.103:2000
NM=255.255.255.0
GW=192.168.0.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.21>
<2.21> get w
SSID=bombara
Chan=11
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=7972mimmo
<2.21>
my router have this configuration
DHCP Server : enabled
ESSID : bombara
Channel : 11
Security : WPA pre-shared key
Encryption : WPA pre-shared key
WPA Type : WPA2(AES)
Pre-shared Key Type : passphrase
Pre-shared Key : 7972mimmo
on the wifi i have slow blink green led, but if i want open the page whit 192.168.0.103:2000
i have error
where is the solution?
dmolton
Re: problem whit wifi
Post by dmolton »
What's the error?
Maybe it's a firewall issue?
petruzzelli
dmolton wrote:What's the error?
i dont have firewall
the problem is the wifi dont have comunication
the led is ok (for it the connection is ok)
when i made the ping i have comunication but 3 poket is ok and lose 1, the router and the wifi module are in the same room.
but if i open the internet page whit this address 192.168.0.103:2000 have the error comunication
if i open the RAclient2.2 and i go to setting where is possible open the service dash in the spase where is possible learn the ip ad the port i dont have the possibility for put it and they are empty
Do you have "#define wifi" in the ReefAngel_Features.h file?
petruzzelli
yes i have
It could be a network issue, not for sure though.
I had to enable the connection timeout on my wifi for me to communicate with my controller. If I did not, one connection would stay open and I could never communicate.
Did you follow the instruction in the manual?
Were you able to see data in Tera Term coming from controller?
petruzzelli
hi roberto
i have use the tera and when i make the connection whit com it is comunicate and the same when i use telnet i have the possibility go inside for configuration whit $$$.
i have made hard reset and i have used the dave software for configuration but i have the same problem.
i open the pag whit 192.168.xx:2000 and i have white page.... if i disconnect to wifi module to reefangel and i open the same page i have the ie error (same time for responding ecc ecc) for this im sure the wifi module have god parametry and have connection whit my router
What I was asking is the little communication code in the manual.
Anyway, here it is:
#include <EEPROM.h>
#include <NokiaLCD.h>
ReefAngel.Init();
ReefAngel.LCD.DrawText(200,36,10,10,"Wifi Test");
ReefAngel.Refresh();
Serial.print("Current Water Temperature is ");
Serial.println(ReefAngel.Params.Temp1);
delay(1000);
Upload to RA and then open Tera Term on 192.168.x.x port 2000.
Do you see anything?
petruzzelli
ok roberto i have
Current Water Temperature is 811
It's the same procedure explained in the manual.
http://www.reefangel.com/files/Reef%20A ... 20v1.3.pdf
Upload the code, attach the wifi and open tera term.
petruzzelli
rimai wrote:It's the same procedure explained in the manual.
ok
but now i have problem whit sketch too big
The code above does not exceed memory.
Don't add it to your own code.
Just use it as is.
You may need to convert to standard libraries if you are getting compile errors: http://forum.reefangel.com/viewtopic.php?f=8&t=2
petruzzelli
rimai wrote:The code above does not exceed memory.
Just use it as is.
1) i know i dont att it
2) i made http://forum.reefangel.com/viewtopic.php?f=8&t=2
but
Binary sketch size: 34512 bytes (of a 30720 byte maximum)
it is my pde
// Autogenerated file by RAGen (v1.0.4.92), (07/27/2011 00:09)
// RA_072711_0009.pde
#define DisplayImages
#define DosingPumpIntervalSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardLights(Port3);
ReefAngel.DosingPumpRepeat1(Port4);
ReefAngel.DosingPumpRepeat2(Port5);
ReefAngel.StandardFan(Port6);
Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
Here is what you need to do:
1. Make sure you close Arduino IDE.
2. Open the file ReefAngel_Features.h located at "Documents\Arduino\libraries\ReefAngel_Features"
3. Change the contents to this:
#define VersionMenu
#define wifi
4. Save the file
5. Open Arduino IDE
6. Upload your PDE file again.
petruzzelli
rimai wrote:Ok, so maybe you didn't have ReefAngel_Features.h file setup correctly.
#define VersionMenu
#define wifi
4. Save the file
5. Open Arduino IDE
sorry change in whit mode' i delete and?
Can you please rephrase? I did not understand. :(
petruzzelli
rimai wrote:Can you please rephrase? I did not understand. :(
sorry
what i do? i opene the features.h and?
Just change the contents.
Delete everything and place just these 2 lines:
#define VersionMenu
#define wifi
petruzzelli
rimai wrote:Just change the contents.
#define VersionMenu
#define wifi
ok roberto
sorry
i have 2 street
the first
settig reefangel whit this software
1) ReefAngelInstaller.exe
2)RAGen-v104-v08516 Installer.exe
second street
1) download arduino 0.22 software on www.arduino.cc
2) download libraries Version 0.8.3.11
3) download curtbinder-ReefAngel-v0.8.5.16-0-ge9a7435
4) RAGen-v104-v08516 Installer.exe
whit ragen i made memory pde and ra pde
if i use this file whit the first street i have sketch too big, if i use the second street it is ok but i dond have comunication whit wifi
why?
Use 1st option.
After you install ReefAngelInstaller and RAGen, you have to one of these 2:
1. Edit the file ReefAngel_Features.h with just the following:
The file has to be edited after you generate your PDE. Everytime you generate a PDE file, RAGen will overwrite whatever change you've made to the file.
#define VersionMenu
#define wifi
2. just uncheck everything from the RAGen when generating the file, except wifi.
You are picking too many choices of RAGen.
petruzzelli
ok tnx
now is all ok
