Lost wifi, I think?
jsclownfish
Lost wifi, I think?
Post by jsclownfish »
I cannot connect to my wifi anymore through the wifi commands or the iPhone. I've restarted it and the light continues to blink green. I noticed the portal is defaulting to a new ip address as well, but the portal seems to be updating from the web banner database. Any ideas what's gone wrong?
Jon
Re: Lost wifi, I think?
Green means it is connected. Did it change ip address?
jsclownfish
Maybe, how do I check that? I have a 2wire system.
Jon
log into your router and check the atached devices
jsclownfish
Looks like it did and the portal figured it out. I may just need to update the port so it shows up in the live connection and iPhone app.
Jon
jsclownfish
OK so I'm a bit lost. :? Honestly, I don't remember how I got it to work last time. ;) I had a dyndys account but I don't think I kept it after the Portal launched because I didn't think I needed it. I guess it is still a good idea for the iphone app. I can see the wifi if I use the IP address 162.x.x.x from the WiFly, but that is only on my local network wireless. If I go 3G or look on the portal that doesn't work and neither does the new IP used by the Broadband 99.x.x.x. Am I missing something?
Jon
port forwarding?
jsclownfish
sorry didn't mention that, but yeah I think the port forward is OK. I'm actually using 162.x.x.x:2000 and it works on my wireless network, but not outside my wireless network and not with the 99.x.x.x:2000 IP.
-Jon
That's exactly what happens when port forwarding is not correct.
You can access internal ip, because there is no need of port forwarding.
Check it in here:
http://www.yougetsignal.com/tools/open-ports/
jsclownfish
:D Got it! Thanks! I was port forwarding from my computer IP, not the WiFly IP. It works now.
Atleast I have this thread now if I forget how to do this again. :lol:
-Jon
