Unexpected Light turning off
Ask in here.
Fireshimp
Post by Fireshimp »
Hi
I need some help regard lighting schedule programimg. I am trying to control light schedule and intensity at diff timing of the day. But the light was turn off by it self (At diff timing for continus 2 day after upload the code) . I cannot turn back on through menu from head unit. to recover, need to power off then on again to resume schedule. Now I donot know it is programing issues or the relay box problem. (I just chage head unit due to joystick problem).
I had attached code below.
Please help
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.StandardLights( Port2,5,55,22,10 );
ReefAngel.Relay.DelayedOn( Port3,60 );
ReefAngel.StandardLights( Port4,22,0,7,0 );
ReefAngel.StandardFan( Port5,270,280 );
ReefAngel.StandardLights( Port7,6,0,22,0 );
ReefAngel.StandardATO( Port8,60 );
//ReefAngel.PWM.SetDaylight( PWMSlope(8,0,22,0,15,90,60,15) );
//ReefAngel.PWM.SetActinic( PWMSlope(8,0,22,0,15,90,60,15) );
//if (hour()==8) ReefAngel.PWM.SetDaylight(20);
//if (hour()==9) ReefAngel.PWM.SetDaylight(40);
//if (hour()==6) ReefAngel.PWM.SetDaylight(0);
//if (hour()==6) ReefAngel.PWM.SetActinic(15);
if (hour()==10) ReefAngel.PWM.SetDaylight(15);
if (hour()==10) ReefAngel.PWM.SetActinic(50);
if (hour()==11) ReefAngel.PWM.SetDaylight(50);
if (hour()==11) ReefAngel.PWM.SetActinic(75);
if (hour()==12) ReefAngel.PWM.SetDaylight(90);
if (hour()==12) ReefAngel.PWM.SetActinic(90);
if (hour()==16) ReefAngel.PWM.SetDaylight(50);
if (hour()==16) ReefAngel.PWM.SetActinic(75);
if (hour()==17) ReefAngel.PWM.SetDaylight(25);
if (hour()==17) ReefAngel.PWM.SetActinic(25);
if (hour()==20) ReefAngel.PWM.SetDaylight(15);
if (hour()==20) ReefAngel.PWM.SetActinic(25);
if (hour()==21) ReefAngel.PWM.SetDaylight(0);
if (hour()==21) ReefAngel.PWM.SetActinic(25);
if (hour()==22) ReefAngel.PWM.SetDaylight(0);
if (hour()==22) ReefAngel.PWM.SetActinic(0);
Fireshimp
Re: Unexpected Light turning off
Post by Fireshimp »
By the way I set light power source at port 2.
Try this:
    if (hour()<10) ReefAngel.PWM.SetDaylight(0);
    if (hour()<10) ReefAngel.PWM.SetActinic(0);
    if (hour()>=12 && hour()<16) ReefAngel.PWM.SetDaylight(90);
    if (hour()>=12 && hour()<16) ReefAngel.PWM.SetActinic(90);
    if (hour()>=17 && hour()<20) ReefAngel.PWM.SetDaylight(25);
    if (hour()>=17 && hour()<20) ReefAngel.PWM.SetActinic(25);
    if (hour()>=22) ReefAngel.PWM.SetDaylight(0);
    if (hour()>=22) ReefAngel.PWM.SetActinic(0);
Amos Poh
Post by Amos Poh »
rimai wrote:Try this:
Thanks Roberto for the help.
Fireshimp do update us if it worked. ;)
Fireshimp
Post by Fireshimp »
Look like it work now. No incident happen today. I will continue to monitor for next cycle.
But anyway, How to explain logic to control PWM can cause relay port to turn it self off?
