Hi
I need some help regard lighting schedule programimg. I am trying to control light schedule and intensity at diff timing of the day. But the light was turn off by it self (At diff timing for continus 2 day after upload the code) . I cannot turn back on through menu from head unit. to recover, need to power off then on again to resume schedule. Now I donot know it is programing issues or the relay box problem. (I just chage head unit due to joystick problem).
I had attached code below.
Please help
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 300 );
ReefAngel.StandardLights( Port2,5,55,22,10 );
ReefAngel.Relay.DelayedOn( Port3,60 );
ReefAngel.StandardLights( Port4,22,0,7,0 );
ReefAngel.StandardFan( Port5,270,280 );
ReefAngel.StandardLights( Port7,6,0,22,0 );
ReefAngel.StandardATO( Port8,60 );
//ReefAngel.PWM.SetDaylight( PWMSlope(8,0,22,0,15,90,60,15) );
//ReefAngel.PWM.SetActinic( PWMSlope(8,0,22,0,15,90,60,15) );
//if (hour()==8) ReefAngel.PWM.SetDaylight(20);
//if (hour()==9) ReefAngel.PWM.SetDaylight(40);
//if (hour()==6) ReefAngel.PWM.SetDaylight(0);
//if (hour()==6) ReefAngel.PWM.SetActinic(15);
if (hour()==10) ReefAngel.PWM.SetDaylight(15);
if (hour()==10) ReefAngel.PWM.SetActinic(50);
if (hour()==11) ReefAngel.PWM.SetDaylight(50);
if (hour()==11) ReefAngel.PWM.SetActinic(75);
if (hour()==12) ReefAngel.PWM.SetDaylight(90);
if (hour()==12) ReefAngel.PWM.SetActinic(90);
if (hour()==16) ReefAngel.PWM.SetDaylight(50);
if (hour()==16) ReefAngel.PWM.SetActinic(75);
if (hour()==17) ReefAngel.PWM.SetDaylight(25);
if (hour()==17) ReefAngel.PWM.SetActinic(25);
if (hour()==20) ReefAngel.PWM.SetDaylight(15);
if (hour()==20) ReefAngel.PWM.SetActinic(25);
if (hour()==21) ReefAngel.PWM.SetDaylight(0);
if (hour()==21) ReefAngel.PWM.SetActinic(25);
if (hour()==22) ReefAngel.PWM.SetDaylight(0);
if (hour()==22) ReefAngel.PWM.SetActinic(0);
Unexpected Light turning off
Fireshimp
Re: Unexpected Light turning off
By the way I set light power source at port 2.
Try this:
if (hour()<10) ReefAngel.PWM.SetDaylight(0);
if (hour()<10) ReefAngel.PWM.SetActinic(0);
if (hour()>=12 && hour()<16) ReefAngel.PWM.SetDaylight(90);
if (hour()>=12 && hour()<16) ReefAngel.PWM.SetActinic(90);
if (hour()>=17 && hour()<20) ReefAngel.PWM.SetDaylight(25);
if (hour()>=17 && hour()<20) ReefAngel.PWM.SetActinic(25);
if (hour()>=22) ReefAngel.PWM.SetDaylight(0);
if (hour()>=22) ReefAngel.PWM.SetActinic(0);
Amos Poh
rimai wrote:Try this:Code: Select all
#include <Salinity.h> #include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <ReefAngel.h> void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.SetTemperatureUnit( Celsius ); // set to Celsius Temperature ReefAngel.AddStandardMenu(); // Add Standard Menu // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port3Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = Port2Bit; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = 0; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 300 ); // Ports that are always on ReefAngel.Relay.On( Port1 ); ReefAngel.Relay.On( Port6 ); ////// Place additional initialization code below here ////// Place additional initialization code above here } void loop() { ReefAngel.StandardLights( Port2,5,55,22,10 ); ReefAngel.Relay.DelayedOn( Port3,60 ); ReefAngel.StandardLights( Port4,22,0,7,0 ); ReefAngel.StandardFan( Port5,270,280 ); ReefAngel.StandardLights( Port7,6,0,22,0 ); ReefAngel.StandardATO( Port8,60 ); //ReefAngel.PWM.SetDaylight( PWMSlope(8,0,22,0,15,90,60,15) ); //ReefAngel.PWM.SetActinic( PWMSlope(8,0,22,0,15,90,60,15) ); ////// Place your custom code below here //if (hour()==8) ReefAngel.PWM.SetDaylight(20); //if (hour()==9) ReefAngel.PWM.SetDaylight(40); //if (hour()==6) ReefAngel.PWM.SetDaylight(0); //if (hour()==6) ReefAngel.PWM.SetActinic(15); if (hour()<10) ReefAngel.PWM.SetDaylight(0); if (hour()<10) ReefAngel.PWM.SetActinic(0); if (hour()==10) ReefAngel.PWM.SetDaylight(15); if (hour()==10) ReefAngel.PWM.SetActinic(50); if (hour()==11) ReefAngel.PWM.SetDaylight(50); if (hour()==11) ReefAngel.PWM.SetActinic(75); if (hour()>=12 && hour()<16) ReefAngel.PWM.SetDaylight(90); if (hour()>=12 && hour()<16) ReefAngel.PWM.SetActinic(90); if (hour()==16) ReefAngel.PWM.SetDaylight(50); if (hour()==16) ReefAngel.PWM.SetActinic(75); if (hour()>=17 && hour()<20) ReefAngel.PWM.SetDaylight(25); if (hour()>=17 && hour()<20) ReefAngel.PWM.SetActinic(25); if (hour()==20) ReefAngel.PWM.SetDaylight(15); if (hour()==20) ReefAngel.PWM.SetActinic(25); if (hour()==21) ReefAngel.PWM.SetDaylight(0); if (hour()==21) ReefAngel.PWM.SetActinic(25); if (hour()>=22) ReefAngel.PWM.SetDaylight(0); if (hour()>=22) ReefAngel.PWM.SetActinic(0); ////// Place your custom code above here // This should always be the last line ReefAngel.ShowInterface(); }
Thanks Roberto for the help.
Fireshimp do update us if it worked.
Fireshimp
Look like it work now. No incident happen today. I will continue to monitor for next cycle.
But anyway, How to explain logic to control PWM can cause relay port to turn it self off?
