I would like my wavemaker ports (5 & 6) to come on for 10 min when the ATO port is switched on.
Thanks in advance.
Current code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Portal( "treetopflyn" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
Need help coding
Re: Need help coding
Even at night?
So, it should come on for 10 min when LowATO is triggered regardless of your other checks?
treetopflyn
Need help coding
That's correct regardless of the other checks I want the power heads to help mix the kalk top-off water in the DT for 10 min
Try this:
boolean OverrideWM=false;
ReefAngel.Timer[1].SetInterval(600);
ReefAngel.Timer[1].Start();
OverrideWM=true;
if (ReefAngel.Timer[1].IsTriggered())
OverrideWM=false;
if (OverrideWM)
int x,y;
// pH Expansion
// Relay Expansion
treetopflyn
Thanks Roberto. I will give it a try.
