Need help coding
treetopflyn
Need help coding
Post by treetopflyn »
I would like my wavemaker ports (5 & 6) to come on for 10 min when the ATO port is switched on.
Thanks in advance.
Current code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port1,60 );
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Portal( "treetopflyn" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
Re: Need help coding
Even at night?
So, it should come on for 10 min when LowATO is triggered regardless of your other checks?
treetopflyn
Need help coding
That's correct regardless of the other checks I want the power heads to help mix the kalk top-off water in the DT for 10 min
Try this:
boolean OverrideWM=false;
  ReefAngel.Timer[1].SetInterval(600);
    ReefAngel.Timer[1].Start();
    OverrideWM=true;
  if (ReefAngel.Timer[1].IsTriggered())
    OverrideWM=false;
  if (OverrideWM)
  int x,y;
  // Parameters
  // pH Expansion
  // Main Relay Box
  // Relay Expansion
  // Date and Time
treetopflyn
Thanks Roberto. I will give it a try.
