ORP Probe interferes with Salinity Probe?
dazza1304
Post by dazza1304 »
Hi,
Just got around to adding my ORP probe and noticed as soon as I put it in the sump, my salinity jumps up about 2 points.
This is immediate and if I remove the ORP probe, the salinity immediately goes down etc.
So there is def some interference from the ORP probe on the salinity.
I also tried placing the probe about a foot away from the salinity probe and exactly the same effect.
Surely this shouldnt happen?
Re: ORP Probe interferes with Salinity Probe?
Correct, this shouldn't happen.
May I ask to use a cup of tank water or any other container and do the same exercise in it?
Does it also interfere the same?
dazza1304
Post by dazza1304 »
Hi Roberto,
Just done this an yes, in a cup it jumps about 2 points also as soon as the ORP electrode is added.
You will need to send them for repair then.
PM for RMA
dazza1304
Post by dazza1304 »
Just for anyone who may have a similar thing, Roberto helped me isolate this, and it was my induced problem as I used the same power supply to power the salinity and ORP module causing the problem.
When using separate supplies, it works fine!!
