Hi! In my relay box, Port 4 (Standar lignhts) does not Work. The RA controler show me '' the Port is open'', but the lights does not open. Until now I have never use the port 4. When i put the lights to an other open Port, the lights Open.
This is a bug or relay problem?
Also when i open and close the port 4 i can not hear the typical Clik that the relay does when open and close one Port.
This is my code:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port7 );
If it's a bad port you'll need to verify using the Relay Box test software. Roberto can advise after that on RMA or other appropriate steps. Your code looks ok...
I don't think show. I try to change the power relay (no 4) inside the main relay and if is not work then we will see!!!! Now i am in the midle of this work and i waet the spare part.....
Hi! Today new problem With relay box....!
1. Stop working the relay 4. when i give them the order to open and close that does not responding!!
2. When open and close relay 2, open and close relay 4 and 6 All together!!!
3. When open and close relay 6, open and close relay 2 and 4 all together!!!
4. Also When i give an order to relay 2 and after i give an order to relay 6 that does not respond and the opposite! The relay 4 still responding only when i give an order to the ather two relays!
Bug or damange from replaced relay?? Yesterday everethink works good
