Invert parabola
Invert parabola
New driver is 0v=100%
How can I invert the PWMParabola in arduino?
Re: Invert parabola
Is that steve's?
Inverted?
Buckpucks are inverted too :(
Re: Invert parabola
Testing buckpack. Anyway to invert PWMParabola? Start at 255 instead of 0. Basically flop it.
Re: Invert parabola
I thought you were going with Steve's?? Changed your mind?
Re: Invert parabola
I'm just trying options. I still have the meanwells too and working on the op amp for them. But I like the idea of 0v=100% just if/when there is a code panic or failure. My lights will at least be on and not off. Ya know?
Re: Invert parabola
Which buckpuck did you get?
For the inverted number, how do invert a number from 100-0 instead of 0-100?? Think about it and let's see if you can give me this answer :)
Re: Invert parabola
I'll have to look at the model..a friend of mine gave it to me for testing IF I like it or not.
I'm guessing the code would go a little something like this:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
int blue1 = 9;             // blue LEDs connected to digital pin 9 (pwm)
int white1 = 6;            // white LEDs connected to digital pin 6 (pwm)
byte InvertActinic=0;
byte InvertDaylight=0;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
IPAddress ip(192,168,1, XXX);
EthernetServer server(84);
/* ******** NTP Server Settings NTP BEGIN ******** */
IPAddress timeServer(50, 77, 217, 185);
IPAddress backupNTP(64, 113, 32, 5); // back up NTP sever
/* Set this to the offset (in seconds) to your local time
 This example is GMT - 6 */
const long timeZoneOffset = -21600L;
/* Syncs to NTP server every 15 seconds for testing,
 set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 3600; //3600 one hour
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
// Do not alter this function, it is used by the system
int getTimeAndDate() {
  int flag=0;
  Udp.begin(localPort);
  sendNTPpacket(timeServer);
  delay(1000);
  if (Udp.parsePacket()){
    Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
    unsigned long highWord, lowWord, epoch;
    highWord = word(packetBuffer[40], packetBuffer[41]);
    lowWord = word(packetBuffer[42], packetBuffer[43]);
    epoch = highWord << 16 | lowWord;
    epoch = epoch - 2208988800 + timeZoneOffset;
    flag=1;
    setTime(epoch);
    ntpLastUpdate = now();
  return flag;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
//NTP END
/*PWM START*/
byte intlength(int intin)
  if (intin>9999) return 5;
  if (intin>999) return 4;
  if (intin>99) return 3;
  if (intin>9) return 2;
  if (intin>=0 && intin<=9) return 1;
  if (intin<0) return 2;
int NumMins(uint8_t ScheduleHour, uint8_t ScheduleMinute)
  return (ScheduleHour*60) + ScheduleMinute;
bool IsLeapYear(int year)
  if (year % 4 != 0)
    return false;
  else if (year % 400 == 0)
    return true;
  else if (year % 100 == 0)
    return false;
  return true;
byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
  int Now = NumMins(hour(), minute());
  int Start = NumMins(startHour, startMinute);
  int StartD = Start + Duration;
  int End = NumMins(endHour, endMinute);
  int StopD = End - Duration;
  if ( Now >= Start && Now <= StartD )
    return constrain(map(Now, Start, StartD, startPWM, endPWM),startPWM, endPWM);
  else if ( Now >= StopD && Now <= End )
    byte v = constrain(map(Now, StopD, End, startPWM, endPWM),startPWM, endPWM);
    return endPWM-v+startPWM;
  else if ( Now > StartD && Now < StopD )
    return endPWM;
  // lastly return the existing value
  return oldValue;
byte PWMParabola(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
  byte PWMDelta = endPWM-startPWM;
  byte ParabolaPhase=constrain(map(Now,Start,End,0,180),0,180);
  if ( Now <= Start || Now >= End)
    return oldValue;
    return startPWM+(PWMDelta*sin(radians(ParabolaPhase)));
/*PWM END*/
void NTP()//loop NTP with one hour refresh
  if(now()-ntpLastUpdate > ntpSyncTime) {
    int trys=0;
    while(!getTimeAndDate() && trys<10){
      trys++;
    if(trys<10)
      // Serial.println("ntp server update success");
    else if (trys>=10 && trys<20)
      sendNTPpacket(backupNTP);
      // Serial.println("backup success");
      // Serial.println("ntp server update failed");
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  int trys=0;
  while(!getTimeAndDate() && trys<10) {
    trys++;
  NTP();
  InvertActinic=(2.55*(PWMParabola(12,1,14,10,22,100,InvertActinic)));
  InvertDaylight=(2.55*(PWMParabola(6,1,21,10,22,100,InvertDaylight)));
  analogWrite(blue1, 255-(InvertActinic));
  analogWrite(white1, 255-(InvertDaylight));
YES, NO, MAYBE SO? :)
Re: Invert parabola
Yeap :)
You got it
Re: Invert parabola
Can you sum that up in one or two lines of code?
Re: Invert parabola
Inverting a number from 0-100 to 100-0 is simple as:
x=100-x;
Re: Invert parabola
I mean having the parabola go from 100 to 0... but I'll look through his code :)
Re: Invert parabola
lnevo wrote:Can you sum that up in one or two lines of code?
Sorry. I have to add that NTP junk to get the time before I can test anything. (I need to buy an RTC) :(
Mines a little different because the PWMSlope & PWMParabola output a percentage...so I have to 2.55*(blah)
So instead of x=100-x; I have to do x=255-x;
I'm using Arduino not the RA..so it has to be 0-255 "steps."
You can see I have to analogWrite(pin, value)...for RA it's different.
So, to sum it up....
int blue1 = 9;             // pin 9 (pwm)
int white1 = 6;           // pin 6 (pwm)
byte InvertActinic=0; //stores variable for InvertActinic
byte InvertDaylight=0; //stores variable for InvertDaylight
void setup(){
void loop() {
  InvertActinic=(2.55*(PWMParabola(12,1,14,10,22,100,InvertActinic))); //Tell what InvertActinic is
  InvertDaylight=(2.55*(PWMParabola(6,1,21,10,22,100,InvertDaylight))); //Tell what InvertDaylight is
  analogWrite(blue1, 255-(InvertActinic)); //What to do with InvertActinic value
  analogWrite(white1, 255-(InvertDaylight)); //What to do with InvertDaylight value
Re: Invert parabola
Got it.. thanks :)
Re: Invert parabola
Cool beans. I think Roberto is on to me. He makes me "earn it" lol!!! :o
Re: Invert parabola
:) lol
