Invert parabola
- DrewPalmer04
Invert parabola
New driver is 0v=100%
How can I invert the PWMParabola in arduino?
- DrewPalmer04
Re: Invert parabola
Testing buckpack. Anyway to invert PWMParabola? Start at 255 instead of 0. Basically flop it.
- DrewPalmer04
Re: Invert parabola
I'm just trying options. I still have the meanwells too and working on the op amp for them. But I like the idea of 0v=100% just if/when there is a code panic or failure. My lights will at least be on and not off. Ya know?
Re: Invert parabola
Which buckpuck did you get?
For the inverted number, how do invert a number from 100-0 instead of 0-100?? Think about it and let's see if you can give me this answer
- DrewPalmer04
Re: Invert parabola
I'll have to look at the model..a friend of mine gave it to me for testing IF I like it or not.
I'm guessing the code would go a little something like this:
YES, NO, MAYBE SO?
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
int blue1 = 9; // blue LEDs connected to digital pin 9 (pwm)
int white1 = 6; // white LEDs connected to digital pin 6 (pwm)
byte InvertActinic=0;
byte InvertDaylight=0;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
IPAddress ip(192,168,1, XXX);
EthernetServer server(84);
/* ******** NTP Server Settings NTP BEGIN ******** */
IPAddress timeServer(50, 77, 217, 185);
IPAddress backupNTP(64, 113, 32, 5); // back up NTP sever
/* Set this to the offset (in seconds) to your local time
This example is GMT - 6 */
const long timeZoneOffset = -21600L;
/* Syncs to NTP server every 15 seconds for testing,
set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 3600; //3600 one hour
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
// Do not alter this function, it is used by the system
int getTimeAndDate() {
int flag=0;
Udp.begin(localPort);
sendNTPpacket(timeServer);
delay(1000);
if (Udp.parsePacket()){
Udp.read(packetBuffer,NTP_PACKET_SIZE); // read the packet into the buffer
unsigned long highWord, lowWord, epoch;
highWord = word(packetBuffer[40], packetBuffer[41]);
lowWord = word(packetBuffer[42], packetBuffer[43]);
epoch = highWord << 16 | lowWord;
epoch = epoch - 2208988800 + timeZoneOffset;
flag=1;
setTime(epoch);
ntpLastUpdate = now();
return flag;
unsigned long sendNTPpacket(IPAddress& address)
memset(packetBuffer, 0, NTP_PACKET_SIZE);
packetBuffer[0] = 0b11100011;
packetBuffer[1] = 0;
packetBuffer[2] = 6;
packetBuffer[3] = 0xEC;
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
Udp.beginPacket(address, 123);
Udp.write(packetBuffer,NTP_PACKET_SIZE);
Udp.endPacket();
//NTP END
/*PWM START*/
byte intlength(int intin)
if (intin>9999) return 5;
if (intin>999) return 4;
if (intin>99) return 3;
if (intin>9) return 2;
if (intin>=0 && intin<=9) return 1;
if (intin<0) return 2;
int NumMins(uint8_t ScheduleHour, uint8_t ScheduleMinute)
return (ScheduleHour*60) + ScheduleMinute;
bool IsLeapYear(int year)
if (year % 4 != 0)
return false;
else if (year % 400 == 0)
return true;
else if (year % 100 == 0)
return false;
return true;
byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
int Now = NumMins(hour(), minute());
int Start = NumMins(startHour, startMinute);
int StartD = Start + Duration;
int End = NumMins(endHour, endMinute);
int StopD = End - Duration;
if ( Now >= Start && Now <= StartD )
return constrain(map(Now, Start, StartD, startPWM, endPWM),startPWM, endPWM);
else if ( Now >= StopD && Now <= End )
byte v = constrain(map(Now, StopD, End, startPWM, endPWM),startPWM, endPWM);
return endPWM-v+startPWM;
else if ( Now > StartD && Now < StopD )
return endPWM;
// lastly return the existing value
return oldValue;
byte PWMParabola(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
byte PWMDelta = endPWM-startPWM;
byte ParabolaPhase=constrain(map(Now,Start,End,0,180),0,180);
if ( Now <= Start || Now >= End)
return oldValue;
return startPWM+(PWMDelta*sin(radians(ParabolaPhase)));
/*PWM END*/
void NTP()//loop NTP with one hour refresh
if(now()-ntpLastUpdate > ntpSyncTime) {
int trys=0;
while(!getTimeAndDate() && trys<10){
trys++;
if(trys<10)
// Serial.println("ntp server update success");
else if (trys>=10 && trys<20)
sendNTPpacket(backupNTP);
// Serial.println("backup success");
// Serial.println("ntp server update failed");
Ethernet.begin(mac, ip);
server.begin();
Serial.begin(57600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
int trys=0;
while(!getTimeAndDate() && trys<10) {
trys++;
NTP();
InvertActinic=(2.55*(PWMParabola(12,1,14,10,22,100,InvertActinic)));
InvertDaylight=(2.55*(PWMParabola(6,1,21,10,22,100,InvertDaylight)));
analogWrite(blue1, 255-(InvertActinic));
analogWrite(white1, 255-(InvertDaylight));
YES, NO, MAYBE SO?
- lnevo
- lnevo
Re: Invert parabola
I mean having the parabola go from 100 to 0... but I'll look through his code
- DrewPalmer04
Re: Invert parabola
lnevo wrote:Can you sum that up in one or two lines of code?
Sorry. I have to add that NTP junk to get the time before I can test anything. (I need to buy an RTC)
Mines a little different because the PWMSlope & PWMParabola output a percentage...so I have to 2.55*(blah)
So instead of x=100-x; I have to do x=255-x;
I'm using Arduino not the RA..so it has to be 0-255 "steps."
You can see I have to analogWrite(pin, value)...for RA it's different.
So, to sum it up....
int blue1 = 9; // pin 9 (pwm)
int white1 = 6; // pin 6 (pwm)
byte InvertActinic=0; //stores variable for InvertActinic
byte InvertDaylight=0; //stores variable for InvertDaylight
void setup(){
void loop() {
InvertActinic=(2.55*(PWMParabola(12,1,14,10,22,100,InvertActinic))); //Tell what InvertActinic is
InvertDaylight=(2.55*(PWMParabola(6,1,21,10,22,100,InvertDaylight))); //Tell what InvertDaylight is
analogWrite(blue1, 255-(InvertActinic)); //What to do with InvertActinic value
analogWrite(white1, 255-(InvertDaylight)); //What to do with InvertDaylight value
- lnevo
- DrewPalmer04
Re: Invert parabola
Cool beans. I think Roberto is on to me. He makes me "earn it" lol!!!
