wifi
805reefer
wifi
Post by 805reefer »
i just got my new controller in the mail today so im trying to hook the wifi up, it tells me to add the code in arduino, i have no idea how to code this is the first time i looked at the coding and wouldnt even know where to add it if i did know how to code can someone please help me out thanks
Re: wifi
Did you try any of the other options?
The easiest is to use the wifi utility.
805reefer
wifi
Post by 805reefer »
That's what I used and it said I need to add it to my controller
Re: wifi
Just to make sure we are talking about the same wifi utility, you are using the same one shown in this thread, right??
http://forum.reefangel.com/viewtopic.php?f=15&t=345
805reefer
Re: wifi
Post by 805reefer »
just figured it out so i have a question i set my router up for port forwarding can i only check my controller if im on a wifi connection not just on my phone provider
dbmet
wifi
Post by dbmet »
You can check on it via wifi or using your phones provider. You want to check and see what DDNS service your router works with. Like no-ip.com,dyndns.
805reefer
Re: wifi
Post by 805reefer »
Do you mean the connection type?
dbmet
wifi
Post by dbmet »
Nope DDNS is a dynamic IP address server.
So no matter what IP address your service provider assigns you -- you will just be able to go to link and it will take you to your reefangel.
This is if you want to use your reefangel outside of your home wifi network.
805reefer
wifi
Post by 805reefer »
Ok so I got the wifi to work in my house I went through the router and set the port forwarding with port as 2000 but when I go to a out side wifi from my house I can't get any readings on my phone ? Help please =)
Re: wifi
805reefer
wifi
Post by 805reefer »
It says it's closed
805reefer
Re: wifi
Post by 805reefer »
Ok figured it with that link you gave me thanks I have another question I do not under stand how to put the ph probe in and what you calibrate it will can you help me please I really appreciate it
Re: wifi
Remove the plastic bottle in the tip of the ph probe.
Connect it in the controller.
Place it in your sump.
If you find the readings are not correct, you will need to calibrate.
You can find info on calibration inside the manual, but pretty easy. Push the joystick and go to ph calibration.
You will need ph7 and ph10 calibration solutions.
Place it in ph7 and wait and push ok button.
Repeat for ph10.
That's it.
805reefer
wifi
Post by 805reefer »
Ok where can I get those? With the wifi I can only control my pwm drivers when I hook it up to my
Computer is that correct is there any way I can control them with the app or even on the controller itself ?
Re: wifi
Your LFS should have it.
To change settings of your dimming channels, or any other setting for that matter, using the smart phone app, you will need to choose internal memory path when generating code with the wizard.
