Wifi issue
ecam
Wifi issue
Post by ecam »
Can someone please help. From what i can tell i've followed everything to the T using the WPS option for connecting the wifi and then running the wizard to setup the controller. And its still not work . Im at my wits end... Please advise. Here is my code and my Router is an Airport extreme (on the PC side)
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
// Hardcode PH calibrations
ReefAngel.PHMin=544; // PH7.0
ReefAngel.PHMax=830; // PH10.0
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.StandardLights( Port3,7,0,19,0 );
ReefAngel.StandardLights( Port4,9,0,15,0 );
ReefAngel.StandardLights( Port5,7,0,19,0 );
ReefAngel.StandardHeater( Port7,765,800 );
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
ReefAngel.AI.SetChannel( White, PWMParabola(9,0,20,0,0,60,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.AI.SetChannel( RoyalBlue, MoonPhase() );
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
ReefAngel.RF.SetChannel( Radion_RoyalBlue, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,100,15) );
if ( second()==0 ) ReefAngel.RF.RadionWrite();
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
805reefer
Wifi issue
Post by 805reefer »
Had the same problem ended up being my IP address... When the wifi wizard completes it's upload does it say successful?
ecam
Re: Wifi issue
Post by ecam »
No. it just sits on Trying to connect to router. and the light is a slow green
805reefer
Wifi issue
Post by 805reefer »
What kind of router do you have
ecam
Re: Wifi issue
Post by ecam »
I have an airport extreme
dbmet
Wifi issue
Post by dbmet »
Looks like the wifi setup has received and IP address from your router. It's the 10.whatever:2000.
It may not me able to setup port forwarding which you may have to do yourself.
805reefer
Wifi issue
Post by 805reefer »
So what I had to do is set up a port forwarding in your router use the IP address that the wizard gave you make sure your port is 2000 in your port forwarding then rerun the wifi wizard again
ecam
Re: Wifi issue
Post by ecam »
I did that and I ran the utility that Robert gave and it says my port is open.
805reefer
Wifi issue
Post by 805reefer »
When you run that utility he gave you right where you put in your IP address in blue it says use current IP address click that and it will give you your current IP address what ever it gives you put that IP in your phone or in the portal for your IP and leave the port as 2000
Re: Wifi issue
it looks good.... try going to http://10.0.1.3:2000 in your web browser
ecam
Re: Wifi issue
Post by ecam »
lnevo wrote:it looks good.... try going to http://10.0.1.3:2000 in your web browser
Not working... says no connection
Wifi issue
Can you ping the IP address? Everything else looks good. Wizard was good...port forwarding check is good...slow green light is good...code looks good.
dbmet
Wifi issue
Post by dbmet »
Yup everything looks good. You might unplug the black connector from the wifi module-- wait a few seconds and then plug it back in and see if it connects and you get a slow green blinking light.
ecam
Re: Wifi issue
Post by ecam »
Disconnected and reconnected and still no connection. I'm out of ideas here
dbmet wrote:Yup everything looks good. You might unplug the black connector from the wifi module-- wait a few seconds and then plug it back in and see if it connects and you get a slow green blinking light.
Re: Wifi issue
Are you sure you are in the same network?
Can you ping the module?
ecam
Re: Wifi issue
Post by ecam »
rimai wrote:Are you sure you are in the same network?
Roberto, yes i can ping it....
and the portal still says an unreachable port, and the forwarding wizard says its open...
Wifi issue
Maybe an ip conflict? May need to check the port settings on the module. All i can think of...
ecam
Re: Wifi issue
Post by ecam »
lnevo wrote:Maybe an ip conflict? May need to check the port settings on the module. All i can think of...
How do i do that?
Wifi issue
Serial terminal program.. Command is 'get e' the manual should have details on setting up the session. For an ip conflict. Disconnect the module and try pinging again.
805reefer
Re: Wifi issue
Post by 805reefer »
Did you do what I told you go here http://www.yougetsignal.com/tools/open-ports/
Then click on the blue label that says use current ip click on that when the ip comes up change only the port number to 2000 then run the check if. It says port open use the ip address that's on the screen for you phone or portal
