pc wont connect
pc wont connect
Just recieved my long awaited RA today, opened it and looked everything over, everything looks good.
Now my problem, I cannot get my PC to pick it up when it is hooked up through USB. It doesnt seem right to me but maybe it is, i have to have the head unit hooked up to the relay box and the relay box plugged in for the head unit to turn on, i would have thought if I plugged in the usb cable to the computer and the 6 wire cord into the head unit it would power it up. Maybe not.
Any help would be great and im sure I will have more questions later.
pc wont connect
You need to have the head unit plugged into the relay box, and the relay box plugged into the wall.
Re: pc wont connect
Yes, I have done that but the pc won't recognize that the ra is plugged in via usb
Sent from my EVO using Tapatalk 2
Re: pc wont connect
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop'
is what I get when i try and upload to get stock program
Re: pc wont connect
It looks like you have no code at all.
This error happens when you are trying to upload a blank sketch.
Re: pc wont connect
Yes, during install of the program I never got the message saying drivers were installed even after waiting for a half hour.
Re: pc wont connect
Check your device manager. Do you have a USB Serial Adapter under COM & LPT Ports?
Re: pc wont connect
Yes
Re: pc wont connect
Crap.... I lied I think..... All it says is usb serial port(com3)
Re: pc wont connect
Yes, it is correct...
COM3 is the serial port you will use to communicate with the controller.
Drivers are installed correctly.
Re: pc wont connect
So what am I doing wrong?
Re: pc wont connect
It doesn't say what's is connected just what port it is.
Re: pc wont connect
It already did.
Your USB-TTL cable drivers are already installed correctly.
Windows doesn't see the controller. It only sees the cable and you communicate to the controller through the cable.
It's a USB-TTL cable from FTDI: http://www.ftdichip.com/Products/Cables ... Serial.htm
Now, you need to upload your code. Either copy one of the existing ones, use one of the example codes or generate one with the wizard.
Re: pc wont connect
I've tried making a scetch with wizard and when I try and upload it I get a bunch of errors
Re: pc wont connect
Yes give me just I while
Re: pc wont connect
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Relay Expansion Module
PH Expansion Module
Standard Menu
Binary sketch size: 29,270 bytes (of a 30,720 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b57600 -D -Uflash:w:C:\Users\NALOGS~1\AppData\Local\Temp\build1723728085333315681.tmp\sketch_apr19c.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: 3 [33]
avrdude: stk500_getsync(): not in sync: resp=0x33
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
PH Expansion Module
Standard Menu
Re: pc wont connect
and here is the code
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,551,815 );
ReefAngel.StandardATO( Port2,60 );
ReefAngel.StandardLights( Port3,15,0,0,0 );
ReefAngel.WavemakerRandom( Port5,4,100 );
ReefAngel.WavemakerRandom( Port6,24,100 );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
int x,y;
// pH Expansion
// Relay Expansion
Re: pc wont connect
just the regular not the plus
Re: pc wont connect
Make sure you have Reef Angel controller w/ optiboot selected under Tools->Board
