data e time
marco3020
data e time
Post by marco3020 »
good morning how I can put the item on the main display setup command to set the time and date? thanks to all
Re: data e time
marco3020
Re: data e time
Post by marco3020 »
not fuction
plesae add in this file in setup menu add time date thanks
marco3020
Re: data e time
Post by marco3020 »
i have cleaning reef angel 1.02 and have install reef angel version 1.02a i have update libraries version 1.03
not fuction
i have this code wharis error?
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define WDT
#define SIMPLE_MENU
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
ReefAngel.AddDateTimeMenu();
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.SingleATO( true,Port1,60,0 );
ReefAngel.StandardLights( Port2,7,0,18,0 );
ReefAngel.StandardHeater( Port3,251,261 );
ReefAngel.StandardFan( Port4,271,261 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.CO2Control( Port8,620,650 );
ReefAngel.PWM.SetDaylight( PWMSlope(6,40,18,0,6,100,60,6) );
ReefAngel.PWM.SetActinic( PWMSlope(6,00,18,0,6,100,60,6) );
if (((NumMins(hour(),minute()) >= NumMins(0,00)) && (NumMins(hour(),minute()) <= NumMins(6,00))) || (NumMins(hour(),minute()) >= NumMins(12,00)) && (NumMins(hour(),minute()) <= NumMins(18,00)))
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
// accensione pompa sx dalle 06:00 alle 12:13 e dalle 18:00 alle 23:59
if (((NumMins(hour(),minute()) >= NumMins(6,00)) && (NumMins(hour(),minute()) <= NumMins(12,00))) || (NumMins(hour(),minute()) >= NumMins(18,00)) && (NumMins(hour(),minute()) <= NumMins(23,59)))
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port6);
Re: data e time
Yes, it is correct.
Are you sure you are uploading the code correctly?
Can you compile and post what it shows in the screen?
marco3020
Re: data e time
Post by marco3020 »
yes
