Turn powerheads off at night
- Rodasphoto
- Contact:
I would like my 2 koralia powerheads to turn off at off at night. How can I program that? (I have 0 experience programming)
Re: Turn powerheads off at night
Which ports are they on and what is your light cycle period?
- Rodasphoto
- Contact:
My photoperiod is 09:00 to 21:00. I believe the power heads are on 5 and 6
Try this:
Make sure to place this code after whatever function you are using for the powerheads.
if (hour()<9 || hour()>=21)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
- Rodasphoto
- Contact:
- Rodasphoto
- Contact:
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.StandardLights( Port2,9,0,21,30 );
ReefAngel.StandardLights( Port3,9,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,20,30 );
ReefAngel.WavemakerRandom1( Port5,60,100 );
ReefAngel.WavemakerRandom2( Port6,60,100 );
ReefAngel.StandardHeater( Port7,778,784 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,80,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,0,30,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,20,0,0,30,0) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,0) );
ReefAngel.Portal( "Rodasphoto" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
