Turn powerheads off at night
Rodasphoto
Post by Rodasphoto »
I would like my 2 koralia powerheads to turn off at off at night. How can I program that? (I have 0 experience programming)
Re: Turn powerheads off at night
Which ports are they on and what is your light cycle period?
Rodasphoto
My photoperiod is 09:00 to 21:00. I believe the power heads are on 5 and 6
Try this:
  if (hour()<9 || hour()>=21)
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
Make sure to place this code after whatever function you are using for the powerheads.
Rodasphoto
Many thanks. Will try.
Rodasphoto
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.StandardLights( Port2,9,0,21,30 );
    ReefAngel.StandardLights( Port3,9,0,20,30 );
    ReefAngel.StandardLights( Port4,9,0,20,30 );
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,60,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,80,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
Should it look like this? I placed the code above where it states put custom code above here
Yeap. You got it :)
