ATO not turning on.
ATO not turning on.
Can anyone see why my Water Level Expansion is not triggering when it gets below 31%?
I've been monitoring it all morning on the portal and it has read 26% all morning.
Also is there a better place to see a history of Relay Activity then the Portal, like the Reef Angel Client?
These areas where changed last night trying to get my De-nitrification chamber working properly.
unsigned long ATOUpdate=0;
And
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
if (ReefAngel.Relay.Status(Port5) && ATOUpdate==0) // Check to see if port 5 is on and update time is empty
{ ATOUpdate = now(); // If so, set the update time to now
ReefAngel.Relay.Off (Port6); } // and turn off the ATO pump
if (now() - ATOUpdate >= 120 && ATOUpdate != 0) // If it's been 120 sec, and the update time is NOT empty
{ ATOUpdate = 0; // Empty out the update time
ReefAngel.WaterLevelATO(Port6,720,29,31); } // and turn the ATO sensor back on
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
    ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
    //Set Standard Menu
    ReefAngel.AddStandardMenu();
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Portal( "Sacohen","Seth0310" );
    int x,y;
    // Parameters
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
    // Main Relay Box
    // Date and Time
byte MyCustomWave(byte maxspeed)
  static byte randomspeed=0;
  if (now()%11<5)
    return randomspeed;
  else if (now()%11>=5 && now()%11<10)
    return maxspeed;
    randomspeed=random(35,maxspeed);
    return 0;
Re: ATO not turning on.
I think it is related to the delay you have in there.
I'm not familiar with the water level sensor. Where it it initially called? The only reference I see to port 6 is in out delay code.
The Water Level Sensor is call in the libraries I think by the following code...
ReefAngel.WaterLevelATO(Port6,720,29,31;
It means start the pump plugged into Port6 when then percentage of water in the sensor goes below 29% and stop it when it reaches 31%. The time out is 720 in this case because I'm using a Tom's Aqua lifter to feed the water and they are very slow pumps (3g/h if I remember correctly).
