I've been monitoring it all morning on the portal and it has read 26% all morning.
Also is there a better place to see a history of Relay Activity then the Portal, like the Reef Angel Client?
These areas where changed last night trying to get my De-nitrification chamber working properly.
unsigned long ATOUpdate=0;
And
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
if (ReefAngel.Relay.Status(Port5) && ATOUpdate==0) // Check to see if port 5 is on and update time is empty
{ ATOUpdate = now(); // If so, set the update time to now
ReefAngel.Relay.Off (Port6); } // and turn off the ATO pump
if (now() - ATOUpdate >= 120 && ATOUpdate != 0) // If it's been 120 sec, and the update time is NOT empty
{ ATOUpdate = 0; // Empty out the update time
ReefAngel.WaterLevelATO(Port6,720,29,31); } // and turn the ATO sensor back on
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.Relay.On( Port4 );
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
