wifi 0.0.0.0:2000 address
aranax
Post by aranax »
Hey guys,
Can you please help? No matter what I do I can 't get an IP associated to the wifi unit. I'm unsing the wizard and this is what I keep getting:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM11
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM11
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM11
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.00>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 -1 10 config
< 23 -1 10 user
< 34 83648 3 WiFly_GSX-2.45
< 78 86328 3 wifly-GSX-400
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 127 Free, Boot=78, Backup=2
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w s Home$Network
< set w s Home$Network
< AOK
< <4.00>
> set w p g0willy!P@ssw0rd
< set w p g0willy!P@ssw0rd
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Home Network
< Chan=1
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router Xtreme N GIGABIT Router
Port 2000 is now being forwarded to 0.0.0.0
< CMD
> ftp u
< ftp u
< <4.00>
< FTP connecting to 198.175.253.161
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 -1 10 config
< 23 -1 10 user
> load user
< <4.00>
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Home Network
< Chan=1
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
My router works fine, I have access to the net and all my comps are working properly. Please help. Thanks.
Jeremiah
aranax
Re: wifi 0.0.0.0:2000 address
Post by aranax »
I tried to upload via Arduino and I get this:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 14,084 bytes (of a 258,048 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM11 -b115200 -D -Uflash:w:C:\Users\jmaza\AppData\Local\Temp\build6747224202757743466.tmp\WifiSetup.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM11
         Using Programmer              : stk500v2
         Overriding Baud Rate          : 115200
avrdude: Recv:
avrdude done.  Thank you.
Appleseed
Post by Appleseed »
Hi do a factory reset again and try the following commands.
obviously change somessid and somepassword to your ssid and password
Also i noticed you may be running mixed mode (wpa and wpa2) on router router, I used to do that and had a issues with my wifi module connecting so it might be worth setting your router to WPA2/AES if possible
save
set wlan ssid somessid
set wlan pass somepassword
set option deviceid ReefAngelWifi
set w j 1
set c c 0
set c r 0
set c o 0
set c i 3
set dns name www.reefangel.com
set i h 198.171.134.6
set i r 80
set i f 0x06
set s t 0x10
set u m 2
set i p 2
set u b 57600
set s p 0
set c s 1420
save
reboot
aranax
Post by aranax »
Thanks Appleseed. Tera Term won't even connect. I'm getting "Connection timed out error". I'm stepping through the setup exactly as stated in the manual but it won't seem to connect. I'm assuming you wanted me to run those commands via the Tera Term, correct? Thanks again.
Jeremiah
Appleseed
Post by Appleseed »
I assume you are connecting to the module via the usb cable? If so double chech that you are connected to the right com port and the the port speed is correct.
Sent from my GT-I9100 using Xparent Green Tapatalk 2
aranax
Post by aranax »
yep. USB cable. verified port via Arduino. I tried telnet and going straight to the serial port from new connection rather than TCP/IP then serial as per the manual. Neither worked. Do you know of any other way to establish a connection? Thanks again.
Appleseed
Post by Appleseed »
Not sure why you would try telnet?
I assume the usb cable is connected to the module directly.
I dont use teraterm but are your settings are as per step 13 in the wifi attachment manual?
I am not aware of any other way to connect to the module.
aranax
Post by aranax »
I tried telnet because nothing seems to work so it was more a shot in the dark than anything else. Settings are the same. I'm stuck.
Appleseed
Post by Appleseed »
when you open teraterm and you select serial on does it say com x: usb serial?
aranax
Post by aranax »
USB.
COM11: USB Serial Port (COM11)
Appleseed
Post by Appleseed »
the only other thing i can think of is the cable connected to the module correctly, as per step 2.
or maybe try using putty or hyperterminal to connect.
aranax
Post by aranax »
Thanks for your help Appleseed. I was monkeying around with and it looks like I finally got an IP address. I'm going to run through the rest of setup to see how things go. Thanks again.
aranax
Post by aranax »
Looks good so far. Minus the port forwarding. I opened it on my router (D-Link) but is doesn't seem to be open when checked on http://www.yougetsignal.com/tools/open-ports/ even after I restarted the router. Did you get yours to properly forward (I know its router specific though)?
Appleseed
Post by Appleseed »
my port forwarding works fine, can you ping your module.
aranax
Post by aranax »
Yeah I can ping it.
aranax
Post by aranax »
I now get OPEN Port confirmation (2000) from canyouseeme.org. YAY! However, portal still shows address unreachable.
I had to reserve the IP assigned to the wifi attachment to make sure it didn't change when rebooting my router.
aranax
Post by aranax »
I verified that the port is open.
I can turn on/off ports via wifi on the RA Client.
I verified that the key is correct in code and uploaded to the RA
I still get Connect Status: Unreachable address
iPhone app won't refresh.
Can someone please help? Thanks.
Jeremiah
aranax
Post by aranax »
<sigh> This is frustrating. Everything was working aside from Portal. I wanted to verify that portal key was loaded properly so launched Arduino and was prompted to update to 1.0.9 (from 1.0.6). I updated hoping it would help solve any "other" issues. Now I can't connect to RA Client via wifi anymore.
...back to square one...
Can you post your code?
aranax
Post by aranax »
Sure. RA Client is running again. Issues are still with Portal (Unreachable Address).
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port4Bit;
    ReefAngel.LightsOnPorts = Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port4Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardLights( Port3,9,0,19,0 );
    ReefAngel.StandardHeater( Port4,751,771 );
    ReefAngel.StandardLights( Port5,9,0,15,30 );
    ReefAngel.StandardLights( Port6,15,0,21,0 );
    ReefAngel.StandardFan( Port7,771,781 );
    ReefAngel.StandardLights( Port8,9,0,21,0 );
    ReefAngel.MHLights( Box1_Port1,13,0,18,0,5 );
    ReefAngel.MHLights( Box1_Port2,13,0,18,0,5 );
    ReefAngel.MHLights( Box1_Port3,13,0,18,0,5 );
    ReefAngel.StandardLights( Box1_Port4,11,0,20,0 );
    ReefAngel.StandardLights( Box1_Port5,12,0,21,0 );
    ReefAngel.StandardLights( Box1_Port6,21,0,2,0 );
    ReefAngel.DosingPumpRepeat( Box1_Port7,0,60,10 );
    ReefAngel.PWM.SetChannel( 0, MoonPhase() );
    ReefAngel.RF.SetMode( Constant,50,10 );
    ReefAngel.Portal("mylogin","mypassword");
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,68, "PHE:" );
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,68, ReefAngel.Params.PHExp );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,68, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,68, ReefAngel.WaterLevel.GetLevel() );
    ReefAngel.LCD.DrawOutletBox( 12, 81, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
Reconfirmed that port 2000 is open via Canyouseeme.org
Thanks Roberto.
According to your webbanner, the server is receiving data.
Last update was less than 5 min ago.
What happens when you click the ip address on the portal page?
aranax
Post by aranax »
I get URL can't be shown on iPad. And a timeout from my computer.
Banner updates but the other features say I need a valid ip address (Internal memory, date and time, etc.)
If you can't connect using wan ip address, the portal can't either.
There is still something not working right with the port forwarding.
aranax
Post by aranax »
Is there something I can test to isolate the issue? All the port forwarding check site show that the port is open. Thanks Roberto.
aranax
Post by aranax »
Hey Roberto. It's working now. Thanks for help. You asking me to click on my the IP address prompted me to take a "real" look at it. The IP always updated automatically when my router got assigned a new Dynamic IP so I assumed all was well. Turns out that it was missing the port information under User Control Panel --> Profile --> WiFi Address. So even though the IP was correct and updating it was not complete. Now things seem fine. Thanks again.
Jeremiah
Awesome!!
