Dear all i want to switch off this ports while on feeding mode and the off when feeding mode is over.
but it does goes off when on feeding mode and dosnt goes on again when feeding mode is over. what iam i lacking?
*Note that port3 and Box1_Port8 are on always on mode.
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.PWM.SetChannel(0,75);
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.Off( Box1_Port8 );
Need help with Feeding mode
Re: Need help with Feeding mode
You probably need an else statement to turn it on again
any idea how to code the else mode?wideawake wrote:You probably need an else statement to turn it on again
} else {
ReefAngel.Relay.On(Box1_Port8);
} else {
lnevo wrote:if (ReefAngel.DisplayedMenu==FEEDING_MODE)
} else {
Thanks Lee
Amos Poh wrote:lnevo wrote:if (ReefAngel.DisplayedMenu==FEEDING_MODE)
} else {
Thanks Lee
Works
