Need help with Feeding mode
Amos Poh
Post by Amos Poh »
Dear all i want to switch off this ports while on feeding mode and the off when feeding mode is over.
but it does goes off when on feeding mode and dosnt goes on again when feeding mode is over. what iam i lacking?
*Note that port3 and Box1_Port8 are on always on mode.
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.PWM.SetChannel(0,75);
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.Off( Box1_Port8 );
wideawake
Re: Need help with Feeding mode
Post by wideawake »
You probably need an else statement to turn it on again
Amos Poh
Post by Amos Poh »
wideawake wrote:You probably need an else statement to turn it on again
any idea how to code the else mode? :D
Amos Poh
Post by Amos Poh »
lnevo wrote:if (ReefAngel.DisplayedMenu==FEEDING_MODE)
Thanks Lee :D
Amos Poh
Post by Amos Poh »
Thanks Lee :D
Works :D Thanks
