wp40s seem under powered
aqua man 07
Post by aqua man 07 »
OK I'll start by saying I am new to using the reef angel and used the wizard to get my pumps working. I have them on long pulse at 100 for 5 sec. But compared to the stock controller they seem really weak like they are only running at 30 or 40%. Secondly I kinda liked the else mode on the stock controller. Is there a way to modify the code I made with the wizard to use this mode and speed them up. I also do not have internet on the PC I am using I just have my phone for the moment.
ReEfnWrX
Re: wp40s seem under powered
Post by ReEfnWrX »
I love my wp40. I would agree that I felt the Reefcrest mode was on the weaker side. compared to else mode, others have mentioned this too.
However, in Nutrient Transport mode when it is doing short pulses at 70% power, I get a wave with about a 2" difference from the trough to the crest and my pump is about 10" below the water line... that is some serious water movement.
Someone created an else like mode.
In your INO file, at the very end of everything
past this code in
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Then to use it, in your void loop()
change
ReefAngel.DCPump.UseMemory = True;
to
and add this - also in the void loop()
ReefAngel.PWM.SetDaylight( ElseMode(55,20,true) );
If you are using the daylight dimming channel, otherwise it would be SetActinic unless you are using a dimming expansion then the you we need to call the appropriate channel.
aqua man 07
I am using 2 wp40's and the seem weak on any mode I'm useing a ra+ with pmw I can't even get reef crest to work properly. I'll post my code as soon as I can.
aqua man 07
Can I add a second wp40 on this code.
What port are they connected to? They should not be any weaker than the stock controller... Posting your code as you mentioned would help a bit.
You can run quite a few depending what hardware you have
aqua man 07
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 805 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.CustomLabels[0]="return";
    ReefAngel.CustomLabels[1]="skimmer";
    ReefAngel.CustomLabels[2]="heater";
    ReefAngel.CustomLabels[3]="blank";
    ReefAngel.CustomLabels[4]="sump light";
    ReefAngel.CustomLabels[5]="blank";
    ReefAngel.CustomLabels[6]="frag tank";
    ReefAngel.CustomLabels[7]="blank";
    ReefAngel.StandardHeater( Port3,790,795 );
    ReefAngel.StandardLights( Port7,10,0,22,0 );
    ReefAngel.DCPump.SetMode( LongPulse,100,5 );
aqua man 07
I I tried to code posted above but it keeps telling me that ElseMode was not declared.
ReEfnWrX
Post by ReEfnWrX »
are you putting the Else mode code at the very END of your coding, literally after everything.
Can you post your code please
aqua man 07
Is it possible I need to update something.
aqua man 07
OK it took so to add a second wp 40 do I just add it on the Attinic channel on false
aqua man 07
both pumps are working now and it looks good All I need to do is play around with the offset of the change in flow
