Controlling Jebao/Tunze/Speedwave pumps
Re: Controlling Jebao/Tunze/Speedwave pumps
I see that the Tunze control in in the portal now. Way cool!. I assume that I need to use internal memory to use the portal. How do I code that for Tunze pumps on a PWM expansion box?
ReefAngel.DCPump.ExpansionChannel[0]=Sync;
ReefAngel.DCPump.ExpansionChannel[1]=AntiSync;
Change the channel number and the type to however you want to configure it. That's all there is to it. If you want you can define the speed for Water Change and Feeding Modes...
ReefAngel.DCPump.FeedingSpeed=10;
Inevo wrote
Today I have tried adding ReefAngel.DCPump.FeedingSpeed=10; to my code, but the pump did not operate during the feed mode. I have tried a number of values up to 50 with the same result.
I am not sure if the ReefAngel.DCPump.FeedingSpeed should work with the ATOPinLow port or not also if it should do I have the command in the right place in my code.
Any suggestions please.
My INO
I have been using the ATOPinLow port and memory settings via the Portal to control my Jeboa for some time.If you want you can define the speed for Water Change and Feeding Modes...
My INO
// Created using Wizard 14/09/2013
// DC pump set to use ATOPinLow
InternalMemory.LCDID_write(0); // new LCD screen
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.DCPump.FeedingSpeed=50;
// ReefAngel.StandardATO( Port2 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync ; // Jebo connected to AtoPINLow
// Waterlevel code changed 20/04/13 to stop quick cycle of ATO pump
byte l = ReefAngel.WaterLevel.GetLevel();
if (l>85) ReefAngel.Relay.Off(Port2);
if (l<82 && l>0) ReefAngel.Relay.On(Port2);
if (now()%20<10)
// Delay turning Skimmer back on
ReefAngel.Relay.DelayedOn( Port1,60 );
// Activate Watch Dog Timer at 6am and 6pm
if ((now()%86400)==21600) delay(1000);
if ((now()%86400)==43200) delay(1000);
// Wavemaker not available 9 pm to 10 am
if ( (hour() >= 20) || (hour() <= 9) )
ReefAngel.DCPump.Mode==Custom;
ReefAngel.Portal( "sebyte" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
Where do I post this in my code? Thanks!rimai wrote:Code: Select all
pinMode(lowATOPin,OUTPUT); analogWrite(lowATOPin,ReefCrestMode(60,20,true)*2.55);
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
above the "place custom code below here"? Thanks again Roberto
Barry
Got it working. Thanks!
Barry
Is it odd that both of my float switch ports run my wp40?
Barry
Anybody?ReeferBee wrote:Is it odd that both of my float switch ports run my wp40?
I don't want to kill the pump if it's only supposed to be ran on a particular float switch port.
Barry
That's what I thought. I cannot tell a difference between the two ports. Is the low port the one on the right? Both seem to run the wp40 the same. I'll post my code. Maybe I have it in the wrong place.
Barry
I have 2 wp25's that I have in my analog dimming channels. I ran the wizard to set them up, and now I am confused. I wanted to set them Reef Crest. First I set them at 90% one sync, the other antisync. I would notice one would at times be off. Then I put them at 90% both sync and at times they would both stop. Now I have them both at 90% antisync. So far I have not seen them stop, but not seeing that much of a variance in speeds. Are there adjustments? I'm used to Else modes where I could hear major speed changes. The code samples on the front page don't look like the ones that the wizard generated.
Sorry for all the noob ?'s
I believe this happens when the dimming % drops below 30% on the wp25's.
My guess is you are using the DCPump class..
You could try this instead and set it so your offset does not drop your wave speed below 30%.. 55-25=30
Make sure to set the proper channel whether it is Daylight Actinic or if you are using an expansion etc...
ReefAngel.PWM.SetDaylight( ReefCrestMode(55,25,true); // (byte waveSpeed, byte waveOffset, boolean PulseSync)
I wonder what would happen if you set them to 80% instead of 90%.
ReefCrest has a +/- 20% variance. What I'm thinking is if there is any problems when the % goes above 100%.
That makes sense. I'm used to else mode, so I was thinking 90% was max speed.
What is the duration setting, and can I adjust it?
Sent from my SCH-I535 using Tapatalk
That makes sense, I was using else mode, so I was thinking 90% was max speed.
What is the duration setting on reef crest, and can it be adjusted?
I have some question, i have 2 jaebo and one tunze, but i have only 2 ports on relay. Where cai i connect tunze pump?
Enviado desde mi GT-I9300 mediante Tapatalk
I have it and i use it for my pwm led, i have some free ports, how i can use it the free ports for the tunze?
Do you have the RA Tunze cable?
You can cut the connector of the Tunze cable and connect it to the dimming module.
Maybe I'm wrong, but I was looking at the description of the Tunze cable and it says to connect it to any analog port.
ritorres said he had the PWM dimming module is the Tunze cable Analog/PWM like the Jebao cable is?
ritorres if you open your dimming module up and there are jumpers in it then you have one of the newer modules that you can choose between Analog or PWM.
If you have the older one that is just PWM, I would put one of the Jebaos on the PWM dimming module since that cable can work with either analog or PWM.
Ok.
Ritorres what type of head unit do you have Analog or PWM?
Also look inside the dimming unit and see if you can switch some of the ports to analog with jumpers.
I use pmw led i think pwm dimming unit, how can i chnage with jumper?, some thread or diagram please ![Smile :)](./images/smilies/icon_e_smile.gif)
When you open up the dimming module if you see the following...
![Image](http://i282.photobucket.com/albums/kk250/sac9665/DimmingModulePins_zpse27a7649.png)
You will need to put a jumper across the ports that you want to change to Analog.
The jumpers are the same as you would put on a computer motherboard or hard drive.
Thanks ![Smile :)](./images/smilies/icon_e_smile.gif)
