Custom Menu with Flexible Ph Calibration
rrodriguess
Hi
Since my PH is acid, I use the UseFlexiblePhCalibration() option. It used to work ok.
But with my custom menu, I call the SetupCalibratePH() as below:
void MenuEntry5()
ReefAngel.SetupCalibratePH();
It always shows the "simple" Setup Calibrate PH Screen, not the Flexible one (even if the "UseFlexiblePhCalibration" option is set on the "setup" section).
I found in somewhere a SetupCalibrateChoicePH() to use instead of SetupCalibratePH(), but it's not working too (I get a compile error).
Does anyone have any idea?
Best regards
Rafa
void MenuEntry5()
Best regards
Rafa
rrodriguess
Re: Custom Menu with Flexible Ph Calibration
Sure...
void startTimeRunningRetPump();
void checkMaxSewer();
void checkMinWaterSump();
void checkMaxWaterSump();
void emergencyShutDown();
void WChange();
void DrawCustomMain();
void feedingMode();
// Custom Menu Code
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Auto Feed";
prog_char menu3_label[] PROGMEM = "Water Level Calib.";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Emergency Shut Down";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
menu0_label, menu1_label, menu2_label,
menu3_label, menu4_label, menu5_label,
menu6_label, menu7_label//, menu7_label, menu8_label
//auto feed option on feed mode
boolean auto_Feed=false;
//Water Change Status
int wc_status=1;
// 0 - Troca de agua nao esta pronta
// 1 - Pronto para troca de agua
// 2 - transferir do reservatorio para o sump
// 3 - transferir do sump para o esgoto
// 4 - prepara timer dosador
// 5 - inicia dosador
// 6 - preencher reservatorio
boolean RETPUMP_ON_TIME=false;
//Rename ports
#define LIGHTS Port1
#define RETPUMP Port2
#define COOLER Port3
#define CO2UV Port4
#define WIN Port5
#define WCHANGE Port6
#define WOUT Port7
#define DOSER Port8
//Labes name - RA MENU
#define RA_NAME_LABEL "RAFALU"
#define TEMP_LABEL "TEMP:"
#define PH_LABEL "PH:"
#define LIGHTS_LABEL "Lights"
#define RET_PUMP "RetPump"
#define COOLER_LABEL "Cooler"
#define CO2UV_LABEL "CO2/UV"
#define WATER_IN_LABEL "WIn"
#define WATER_CHANGE_LABEL "WChange"
#define WATER_OUT_LABEL "WOut"
#define DOSER_LABEL "Doser"
//Define WaterLevel Channels
#define WL_SEWER 1
#define WL_REFUGIUM 2
#define WL_SUMP 4
#define WL_RESERVOIR 3
//Define Max and Min PH
#define MAX_PH 610
#define MIN_PH 630
//Define times to Auto Water Change (AWC)
#define WCHANGE_H_T1 9
#define WCHANGE_M_T1 0
#define WCHANGE_H_T2 21
#define WCHANGE_M_T2 0
//Min e Max parameters to Auto Water Change (AWC)
#define MIN_SEWER 10 //maximo tamanho do esgoto para iniciar a troca
#define MIN_RESERVOIR 95 //minimo do reservatorio para iniciar troca parcial
#define MAX_RESERVOIR 100 //maximo para encher reservatorio
#define MAX_SUMP 60 //valor ideal do sump no final da troca
#define MIN_RESERVOIR_AT_CHANGE 10 //minimo do reservatorio na troca
#define MAX_SEWER 70 //maximo tamanho do esgoto para iniciar a troca
//Minimun Sump Level, preventing pump damage
#define MIN_WATER_SUMP 40
//Doser Time for Auto Water Change (AWC)
#define WCHANGE_DOSER_SECOND 5
//Time On/Off Lights
#define LIGHTS_ON_H 19
#define LIGHTS_ON_M 0
#define LIGHTS_OFF_H 23
#define LIGHTS_OFF_M 59
//Time do auto-feed
#define FEEDING_H_T1 20
#define FEEDING_M_T1 30
#define FEEDING_H_T2 23
#define FEEDING_M_T2 20
//Overheat temp, in celcius
#define OVERHEATTEMP 330
//Max and Min tenperature, in celcius
#define TEMP_MIN 280
#define TEMP_MAX 290
//Seconds return pump is on before checking min-water level.
#define RETURN_PUMP_SECONDS_ON 60
//Number of feeding times done in 15 minutes
#define FEEDING_TIMES 2
//Value to avoid change water on every tyne little variation.
#define PROXY_MAX_SUMP 1.10
ReefAngel.SetTemperatureUnit(Celsius); // set to Celsius Temperature
//ReefAngel.FeedingModePorts = Port2Bit;
InternalMemory.OverheatTemp_write(OVERHEATTEMP);
ReefAngel.Relay.On(RETPUMP);
// Ports that are always off
ReefAngel.Relay.Off(WIN);
ReefAngel.Relay.Off(WCHANGE);
ReefAngel.Relay.Off(WOUT);
ReefAngel.Relay.Off(DOSER);
//Use PH Flexible Calibration
//Lights Control
ReefAngel.StandardLights(LIGHTS,LIGHTS_ON_H,LIGHTS_ON_M,LIGHTS_OFF_H,LIGHTS_OFF_M);
//Fam control
//ReefAngel.StandardFan(COOLER,TEMP_MIN,TEMP_MAX);
// CO2/UV Control
ReefAngel.CO2Control(CO2UV,MIN_PH,MAX_PH);
//Auto Water Change (AWC) function
WChange();
//Configra gatilho de 2 minutos de bomba de retorno em execucao
//Function to prevent pump burn
//Funcao para deixar o Sump na medida certa
//Security function on water max level
checkMaxSewer();
//feeding mode
feedingMode();
void startTimeRunningRetPump(){
static boolean timerOn=false;
static long finalTime=0;
if(ReefAngel.Relay.Status(RETPUMP) && !timerOn) {
finalTime = now()+RETURN_PUMP_SECONDS_ON;
timerOn=true;
if(now()>=finalTime && ReefAngel.Relay.Status(RETPUMP)) {
RETPUMP_ON_TIME=true;
if(!ReefAngel.Relay.Status(RETPUMP)){
timerOn=false;
if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)>=MAX_SEWER){
//se agua do sump baixa e bomba retorno ligada
if(RETPUMP_ON_TIME){
if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)<=MIN_WATER_SUMP){
void emergencyShutDown(){
wc_status=0; //inviabiliza futuras trocas de agua
ReefAngel.Relay.Override(WIN,0);
ReefAngel.Relay.Override(WCHANGE,0);
ReefAngel.Relay.Override(WOUT,0);
ReefAngel.Relay.Override(DOSER,0);
ReefAngel.Relay.Override(RETPUMP,0);
ReefAngel.Relay.Override(CO2UV,0);
//se estiver em troca parcial, não mecher.
if(wc_status==1){
if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)> (MAX_SUMP*PROXY_MAX_SUMP) && RETPUMP_ON_TIME){
ReefAngel.Relay.On(WOUT);
else {
void WChange()
static unsigned long wcDosingTimer;
//realiza somente se a bomba retorno esta funcionando a mais de alguns minutos
switch (wc_status){
case 1:
//se execucao manual ou mediante algum horario
if((ReefAngel.DisplayedMenu==WATERCHANGE_MODE) || (hour()==WCHANGE_H_T1 && minute()==WCHANGE_M_T1) || (hour()==WCHANGE_H_T2 && minute()==WCHANGE_M_T2))
if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MIN_RESERVOIR){
wc_status=6;
else{
if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)<=MIN_SEWER){
wc_status=2;
break;
case 2:
//transferir do reservatorio para o sump
if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)>(MIN_RESERVOIR_AT_CHANGE)){
ReefAngel.Relay.On(WCHANGE);
else{
wc_status = 3;
break;
case 3:
//transferir do sump para o esgoto
if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)>(MAX_SUMP)){
else{
wc_status = 4;
break;
case 4:
//prepara timer dosador
wcDosingTimer= now() + WCHANGE_DOSER_SECOND;
wc_status = 5;
break;
case 5:
if (now()<wcDosingTimer) {
ReefAngel.Relay.On(DOSER);
else {
wcDosingTimer=0;
wc_status = 6;
break;
case 6:
//preencher reservatorio, prepara proxima troca
if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MAX_RESERVOIR){
ReefAngel.Relay.On(WIN);
else{
wc_status = 1;
break;
else {
wc_status=1;
void feedingMode(){
static byte nrFeedings=0;
static boolean afeed=false;
static long timeToRun;
static long feeding;
//somente se nao estou fazendo troca automatica
if(wc_status==1){
timeToRun = 900/(FEEDING_TIMES+1);
if(auto_Feed || ((hour()==FEEDING_H_T1 && minute()==FEEDING_M_T1) || (hour()==FEEDING_H_T2 && minute()==FEEDING_M_T2))){
auto_Feed=false;
afeed=true;
feeding = now()+timeToRun;
if(!(ReefAngel.DisplayedMenu==FEEDING_MODE)) ReefAngel.FeedingModeStart();
ReefAngel.Relay.Set(RETPUMP, !(ReefAngel.DisplayedMenu==FEEDING_MODE) );
if(afeed){
if(now()>=feeding && nrFeedings < FEEDING_TIMES){
//if(ReefAngel.Relay.Status(LIGHTS)){
ReefAngel.Relay.Set(COOLER,!ReefAngel.Relay.Status(COOLER));
nrFeedings++;
if(nrFeedings == FEEDING_TIMES){
nrFeedings=0;
afeed=false;
//Titulo Inicial
ReefAngel.LCD.DrawDate(6, 64);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 40, 4 , RA_NAME_LABEL);
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
//Temperatura tanque principal
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 6, 15, TEMP_LABEL);
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 44, 15, text);
//PH
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 26, PH_LABEL);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 44, 26, text);
//WATER LEVEL 01
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, " ");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SEWER), 1);
char str[80];
strcpy (str,"SEWER:");
strcat (str,text);
strcat (str,"%");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, str);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38," ");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_REFUGIUM), 1);
strcpy (str,"REF: ");
strcat (str,text);
strcat (str,"%");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38,str);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, " ");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR), 1);
strcpy (str,"RES: ");
strcat (str,text);
strcat (str,"%");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, str);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50," ");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SUMP), 1);
strcpy (str,"SUMP:");
strcat (str,text);
strcat (str,"%");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50,str);
//Portas
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,RET_PUMP);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,CO2UV_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,WATER_CHANGE_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,DOSER_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,LIGHTS_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,COOLER_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,WATER_IN_LABEL);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,WATER_OUT_LABEL);
ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
void MenuEntry1()
auto_Feed=false;
void MenuEntry2()
auto_Feed=true;
void MenuEntry3()
void MenuEntry4()
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry5()
ReefAngel.SetupCalibrateChoicePH();
void MenuEntry6()
// Clear the screen
// Display some text on the screen
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 5, 10, "Turn Everything Off");
// Turn off the ports
ReefAngel.Relay.Write();
void MenuEntry7()
ReefAngel.SetupDateTime();
void MenuEntry8()
ReefAngel.DisplayVersion();
rrodriguess
Ahhh dont you mind the comments in portuguese... coding in progress...
Rafa
Rafa
Just so we are on the same page, did you download and update your libraries with the dev branch?
rrodriguess
Let me make surge of it, and I get back to you. I will use this library:
https://github.com/reefangel/Libraries
Is that it?
Is that it?
Yes, that is the currently released libraries.
You should use that version unless you were testing or using a feature that is currently not release.
rrodriguess
To be able to use the SetupCalibrateChoicePH() which one should I use?
rrodriguess
Roberto
Just double checked.. I am using the currently release. I get the following error:
Watchdog Timer
Version Menu
Custom Main Screen
Date/Time Setup Menu
Custom Menu
Calibrate pH Menu with Choices
Number of Menu Options: 8
In file included from FreshWaterWord_1_17.cpp:30:
/home/mint/Desktop/Arduino/libraries/ReefAngel/ReefAngel.h:233: error: expected unqualified-id before ‘)’ token
FreshWaterWord_1_17.cpp: In function ‘void MenuEntry5()’:
FreshWaterWord_1_17:558: error: expected unqualified-id before ‘(’ token
Watchdog Timer
Version Menu
Custom Main Screen
Custom Menu
The bug is on the feature.txt file.
It's located at \Arduino\update\
Replace this:
With this:
Replace this:
SetupCalibrateChoicePH,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with ChoicesCode: Select all
SETUP_CALIBRATEPH_CHOICE,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with ChoicesRoberto.
rrodriguess
Roberto.. tks
It compiled alright. As soon as I get home I will upload and test it.
Rafa
Rafa
rrodriguess
