Custom Menu with Flexible Ph Calibration
Ask in here.
rrodriguess
Post by rrodriguess »
Hi
Since my PH is acid, I use the UseFlexiblePhCalibration() option. It used to work ok.
But with my custom menu, I call the SetupCalibratePH() as below:
void MenuEntry5()
ReefAngel.SetupCalibratePH();
It always shows the "simple" Setup Calibrate PH Screen, not the Flexible one (even if the "UseFlexiblePhCalibration" option is set on the "setup" section).
I found in somewhere a SetupCalibrateChoicePH() to use instead of SetupCalibratePH(), but it's not working too (I get a compile error).
Does anyone have any idea?
Best regards
Rafa
Re: Custom Menu with Flexible Ph Calibration
Can I see the code?
rrodriguess
Sure...
void startTimeRunningRetPump();
void checkMaxSewer();
void checkMinWaterSump();
void checkMaxWaterSump();
void emergencyShutDown();
void WChange();
void DrawCustomMain();
void feedingMode();
// Custom Menu Code
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Auto Feed";
prog_char menu3_label[] PROGMEM = "Water Level Calib.";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Emergency Shut Down";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Version";
  menu0_label, menu1_label, menu2_label,
  menu3_label, menu4_label, menu5_label,
  menu6_label, menu7_label//, menu7_label, menu8_label
//auto feed option on feed mode
boolean auto_Feed=false;
//Water Change Status
int wc_status=1;
// 0 - Troca de agua nao esta pronta
// 1 - Pronto para troca de agua
// 2 - transferir do reservatorio para o sump
// 3 - transferir do sump para o esgoto
// 4 - prepara timer dosador
// 5 - inicia dosador
// 6 - preencher reservatorio
boolean RETPUMP_ON_TIME=false;
//Rename ports
#define LIGHTS            Port1
#define RETPUMP           Port2
#define COOLER            Port3
#define CO2UV             Port4
#define WIN               Port5
#define WCHANGE           Port6
#define WOUT              Port7
#define DOSER             Port8
//Labes name - RA MENU
#define RA_NAME_LABEL        "RAFALU"
#define TEMP_LABEL           "TEMP:"
#define PH_LABEL             "PH:"
#define LIGHTS_LABEL         "Lights"
#define RET_PUMP             "RetPump"
#define COOLER_LABEL         "Cooler"
#define CO2UV_LABEL          "CO2/UV"
#define WATER_IN_LABEL       "WIn"
#define WATER_CHANGE_LABEL   "WChange"
#define WATER_OUT_LABEL      "WOut"
#define DOSER_LABEL          "Doser"
//Define WaterLevel Channels
#define WL_SEWER          1
#define WL_REFUGIUM       2
#define WL_SUMP           4
#define WL_RESERVOIR      3
//Define Max and Min PH
#define MAX_PH            610
#define MIN_PH            630
//Define times to Auto Water Change (AWC)
#define WCHANGE_H_T1      9
#define WCHANGE_M_T1      0
#define WCHANGE_H_T2      21
#define WCHANGE_M_T2      0
//Min e Max parameters to Auto Water Change (AWC)
#define MIN_SEWER                10 //maximo tamanho do esgoto para iniciar a troca
#define MIN_RESERVOIR            95 //minimo do reservatorio para iniciar troca parcial
#define MAX_RESERVOIR            100 //maximo para encher reservatorio
#define MAX_SUMP                 60 //valor ideal do sump no final da troca
#define MIN_RESERVOIR_AT_CHANGE  10 //minimo do reservatorio na troca
#define MAX_SEWER                70 //maximo tamanho do esgoto para iniciar a troca
//Minimun Sump Level, preventing pump damage
#define MIN_WATER_SUMP		40
//Doser Time for Auto Water Change (AWC)
#define WCHANGE_DOSER_SECOND     5
//Time On/Off Lights
#define LIGHTS_ON_H      19
#define LIGHTS_ON_M      0
#define LIGHTS_OFF_H     23
#define LIGHTS_OFF_M     59
//Time do auto-feed
#define FEEDING_H_T1     20
#define FEEDING_M_T1     30
#define FEEDING_H_T2     23
#define FEEDING_M_T2     20
//Overheat temp, in celcius
#define OVERHEATTEMP      330
//Max and Min tenperature, in celcius
#define TEMP_MIN		280
#define TEMP_MAX		290
//Seconds return pump is on before checking min-water level.
#define RETURN_PUMP_SECONDS_ON	60
//Number of feeding times done in 15 minutes
#define FEEDING_TIMES			2
//Value to avoid change water on every tyne little variation.
#define PROXY_MAX_SUMP		1.10
  ReefAngel.SetTemperatureUnit(Celsius);  // set to Celsius Temperature
  //ReefAngel.FeedingModePorts = Port2Bit;
  InternalMemory.OverheatTemp_write(OVERHEATTEMP);
  ReefAngel.Relay.On(RETPUMP);
  // Ports that are always off
  ReefAngel.Relay.Off(WIN);
  ReefAngel.Relay.Off(WCHANGE);
  ReefAngel.Relay.Off(WOUT);
  ReefAngel.Relay.Off(DOSER);
  //Use PH Flexible Calibration
  //Lights Control
  ReefAngel.StandardLights(LIGHTS,LIGHTS_ON_H,LIGHTS_ON_M,LIGHTS_OFF_H,LIGHTS_OFF_M);
  //Fam control
  //ReefAngel.StandardFan(COOLER,TEMP_MIN,TEMP_MAX);
  // CO2/UV Control
  ReefAngel.CO2Control(CO2UV,MIN_PH,MAX_PH);
  //Auto Water Change (AWC) function
  WChange();
  //Configra gatilho de 2 minutos de bomba de retorno em execucao
  //Function to prevent pump burn
  //Funcao para deixar o Sump na medida certa
  //Security function on water max level
  checkMaxSewer();
  //feeding mode
  feedingMode();
void startTimeRunningRetPump(){
  static boolean timerOn=false;
  static long finalTime=0;
  if(ReefAngel.Relay.Status(RETPUMP) && !timerOn) {
    finalTime = now()+RETURN_PUMP_SECONDS_ON;
    timerOn=true;
  if(now()>=finalTime && ReefAngel.Relay.Status(RETPUMP)) {
    RETPUMP_ON_TIME=true;
  if(!ReefAngel.Relay.Status(RETPUMP)){
    timerOn=false;
  if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)>=MAX_SEWER){
  //se agua do sump baixa e bomba retorno ligada
  if(RETPUMP_ON_TIME){
    if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)<=MIN_WATER_SUMP){
void emergencyShutDown(){
  wc_status=0; //inviabiliza futuras trocas de agua
  ReefAngel.Relay.Override(WIN,0);
  ReefAngel.Relay.Override(WCHANGE,0);
  ReefAngel.Relay.Override(WOUT,0);
  ReefAngel.Relay.Override(DOSER,0);
  ReefAngel.Relay.Override(RETPUMP,0);
  ReefAngel.Relay.Override(CO2UV,0);
  //se estiver em troca parcial, não mecher.
  if(wc_status==1){
    if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)> (MAX_SUMP*PROXY_MAX_SUMP)  && RETPUMP_ON_TIME){
      ReefAngel.Relay.On(WOUT);
    else {
void WChange()
  static unsigned long wcDosingTimer;
  //realiza somente se a bomba retorno esta funcionando a mais de alguns minutos
    switch (wc_status){
    case 1:
      //se execucao manual ou mediante algum horario
      if((ReefAngel.DisplayedMenu==WATERCHANGE_MODE) || (hour()==WCHANGE_H_T1  && minute()==WCHANGE_M_T1) || (hour()==WCHANGE_H_T2 && minute()==WCHANGE_M_T2))
        if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MIN_RESERVOIR){
          wc_status=6;
        else{
          if(ReefAngel.WaterLevel.GetLevel(WL_SEWER)<=MIN_SEWER){
            wc_status=2;
      break;
    case 2:
      //transferir do reservatorio para o sump
      if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)>(MIN_RESERVOIR_AT_CHANGE)){
        ReefAngel.Relay.On(WCHANGE);
      else{
        wc_status = 3;
      break;
    case 3:
      //transferir do sump para o esgoto
      if(ReefAngel.WaterLevel.GetLevel(WL_SUMP)>(MAX_SUMP)){
      else{
        wc_status = 4;
      break;
    case 4:
      //prepara timer dosador
      wcDosingTimer= now() + WCHANGE_DOSER_SECOND;
      wc_status = 5;
      break;
    case 5:
      if (now()<wcDosingTimer) {
        ReefAngel.Relay.On(DOSER);
      else {
        wcDosingTimer=0;
        wc_status = 6;
      break;
    case 6:
      //preencher reservatorio, prepara proxima troca
      if(ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR)<MAX_RESERVOIR){
        ReefAngel.Relay.On(WIN);
      else{
        wc_status = 1;
      break;
  else {
    wc_status=1;
void feedingMode(){
  static byte nrFeedings=0;
  static boolean afeed=false;
  static long timeToRun;
  static long feeding;
  //somente se nao estou fazendo troca automatica
  if(wc_status==1){
    timeToRun = 900/(FEEDING_TIMES+1);
    if(auto_Feed || ((hour()==FEEDING_H_T1  && minute()==FEEDING_M_T1) || (hour()==FEEDING_H_T2 && minute()==FEEDING_M_T2))){
      auto_Feed=false;
      afeed=true;
      feeding = now()+timeToRun;
      if(!(ReefAngel.DisplayedMenu==FEEDING_MODE)) ReefAngel.FeedingModeStart();
    ReefAngel.Relay.Set(RETPUMP, !(ReefAngel.DisplayedMenu==FEEDING_MODE) );
    if(afeed){
      if(now()>=feeding && nrFeedings < FEEDING_TIMES){
        //if(ReefAngel.Relay.Status(LIGHTS)){
        ReefAngel.Relay.Set(COOLER,!ReefAngel.Relay.Status(COOLER));
        nrFeedings++;
      if(nrFeedings == FEEDING_TIMES){
        nrFeedings=0;
        afeed=false;
  //Titulo Inicial
  ReefAngel.LCD.DrawDate(6, 64);
  ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 40, 4 , RA_NAME_LABEL);
  ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
  ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
  //Temperatura tanque principal
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 6, 15, TEMP_LABEL);
  char text[7];
  ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 44, 15, text);
  //PH
  ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 26, PH_LABEL);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 44, 26, text);
  //WATER LEVEL 01
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, "    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SEWER), 1);
  char str[80];
  strcpy (str,"SEWER:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 38, str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38,"    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_REFUGIUM), 1);
  strcpy (str,"REF: ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 38,str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, "    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_RESERVOIR), 1);
  strcpy (str,"RES:  ");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 6, 50, str);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50,"    ");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(WL_SUMP), 1);
  strcpy (str,"SUMP:");
  strcat (str,text);
  strcat (str,"%");
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 74, 50,str);
  //Portas
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,RET_PUMP);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,CO2UV_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,WATER_CHANGE_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,DOSER_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,LIGHTS_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,COOLER_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,WATER_IN_LABEL);
  ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,WATER_OUT_LABEL);
  ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
void MenuEntry1()
  auto_Feed=false;
void MenuEntry2()
  auto_Feed=true;
void MenuEntry3()
void MenuEntry4()
  ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry5()
  ReefAngel.SetupCalibrateChoicePH();
void MenuEntry6()
  // Clear the screen
  // Display some text on the screen
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 5, 10, "Turn Everything Off");
  // Turn off the ports
  ReefAngel.Relay.Write();
void MenuEntry7()
  ReefAngel.SetupDateTime();
void MenuEntry8()
  ReefAngel.DisplayVersion();
rrodriguess
Ahhh dont you mind the comments in portuguese... coding in progress...
Rafa
Just so we are on the same page, did you download and update your libraries with the dev branch?
rrodriguess
Let me make surge of it, and I get back to you. I will use this library:
https://github.com/reefangel/Libraries
Is that it?
Yes, that is the currently released libraries.
You should use that version unless you were testing or using a feature that is currently not release.
rrodriguess
To be able to use the SetupCalibrateChoicePH() which one should I use?
Use the currently released
rrodriguess
Roberto
Just double checked.. I am using the currently release. I get the following error:
Watchdog Timer
Version Menu
Custom Main Screen
Date/Time Setup Menu
Custom Menu
Calibrate pH Menu with Choices
Number of Menu Options: 8
In file included from FreshWaterWord_1_17.cpp:30:
/home/mint/Desktop/Arduino/libraries/ReefAngel/ReefAngel.h:233: error: expected unqualified-id before ‘)’ token
FreshWaterWord_1_17.cpp: In function ‘void MenuEntry5()’:
FreshWaterWord_1_17:558: error: expected unqualified-id before ‘(’ token
The bug is on the feature.txt file.
It's located at \Arduino\update\
Replace this:
SetupCalibrateChoicePH,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with Choices
With this:
SETUP_CALIBRATEPH_CHOICE,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with Choices
rrodriguess
Roberto.. tks
It compiled alright. As soon as I get home I will upload and test it.
Rafa
rrodriguess
Tks Roberto... it worked just fine!
