Controlling Jebao/Tunze/Speedwave pumps
Would you like to help?
89delta
Re: Controlling Jebao/Tunze/Speedwave pumps
Post by 89delta »
rimai wrote:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ReefCrestMode(60,20,true)*2.55);
analogWrite has a range of 0-255 instead of 0-100
ReefCrestMode is the default setting for the DC pump correct? And if I add ReefAngel.DCPump.UseMemory = true; I can set my pump from the portal or the RA Debug app in development.
89delta
Post by 89delta »
rimai wrote:Remove R2.
rimai, are there any I'll effects by removing both resistors and leaving the cap?
Should be fine.
Actually, if you remove R1, the signal will never reach the pump. You must leave R1.
89delta
Post by 89delta »
Can I substitute the 10k with a 1.8k? At 100% my wp10 doesn't seem to be pushing as hard.
The value won't affect the result, unless you increase to a really larger value, which would cause it to have slow response. You can even remove it and solder the pads together if you want to.
89delta
Post by 89delta »
Thanks rimai. I'll just leave the 10k on R1 then. But other than that it works great using the ATO port.
