I am getting bus locks quite frequently. The status light on the main unit flashes and the date and time settings are also off. I started having this problem after I connected the RA wireless relay box to the expnsion hub using a usb cable. My RANet wireless transmitter is faulty and I cant use the relay wirelessly. I have to disconnect the usb cable for the relay box from the hub, reset the relay box, and then the bus lock goes away. Then I have to reset the date and time on the main head unit. Is there any work around for this problem?
Dr Davaraj
Bus lock
Re: Bus lock
Yes the RANet receiver is still installed in the wireless relay box. Will remove it and let you know how it goes.rimai wrote:Try removing the RANet receiver and see if it makes any difference.
Dr Davaraj
