Bus lock
davaraj
Bus lock
Post by davaraj »
I am getting bus locks quite frequently. The status light on the main unit flashes and the date and time settings are also off. I started having this problem after I connected the RA wireless relay box to the expnsion hub using a usb cable. My RANet wireless transmitter is faulty and I cant use the relay wirelessly. I have to disconnect the usb cable for the relay box from the hub, reset the relay box, and then the bus lock goes away. Then I have to reset the date and time on the main head unit. Is there any work around for this problem?
Dr Davaraj
Re: Bus lock
Try removing the RANet receiver and see if it makes any difference.
davaraj
Re: Bus lock
Post by davaraj »
rimai wrote:Try removing the RANet receiver and see if it makes any difference.
Yes the RANet receiver is still installed in the wireless relay box. Will remove it and let you know how it goes.
Dr Davaraj
