Sunrise Sunset Calculation Durations
clw143
Post by clw143 »
I would like a little help and input on how I would calculate changing the durations (slope) of rising and setting time.
So, as hours per day increase, the duration increases. As hours per day decrease, duration decreases giving the tank the same amount of (insert proper word here... solar radiation??)
I know how to accomplish this in the code, just looking for input on what sort of numbers to apply so the tank is getting "the same amount of light" throughout the varying day lengths.
In my mind this would be something like the period of the curve decreases the duration increases (slopes get steeper) keeping the area under the curve the same? Would that be what I am looking for?
Not exactly to scale, but a reference.
clw143
Re: Sunrise Sunset Calculation Durations
Post by clw143 »
Some quick calculations in excel calculating area under a curve with about a 4 hour per day swing between summer and winter shows I can swing the duration from 2.5 hours for the longest day to 0.5 hours for the shortest day instead of shortening the daylight duration. The duration of 2.5 hours is Actinic Offset as well as the slope duration giving 5 hours or rise time until max light.
Is this data viable and work the way I think it should?
I think you could write something to calculate the amount of time between rise and set and the calculate the slope accordingly.
Actually a map command should do it.
I'll write it up later for you if you need assistance with the code
clw143
Post by clw143 »
It would be cool to see what you come up with.
It's more the question of will coral be ok with more hours with less time at max PAR equally as less hours with more time at max PAR.
It's really a question of what you want to provide. Typically in Winter when it's shorter hours the intensity is technically higher because we're closer to the sun during that part of the year.
For code, try this
int duration=map(NumMins(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute()), 7*60, 13*60, 4*60, 2*60);
That should do it I think. So it's mapping the number of minutes between rise and set and then mapping it from 7-13 hours to 4hours to 2hours. So the shorter the minutes, the closer to 4 hour duration. The longer the daylight time, the closer to 2 hours.
clw143
Post by clw143 »
According to the libraries:
int NumMins  ( uint8_t  ScheduleHour,
  uint8_t  ScheduleMinute
error: too many arguments to function 'int NumMins(uint8_t, uint8_t)
Sorry about that if thats the case you'll need to replace that with NumMins(sl.GetSetHour(), sl.GetSetMinute())-NumMins(sl.GetRiseHour(),sl.GetRiseMinute())
clw143
Post by clw143 »
Why break it apart and not use this?
NumMins(sl.GetSunSet(), sl.GetSunRise()
NumMins takes an hour and a minute. I thought it subtracted the two times.
clw143
Post by clw143 »
So this is the code I ended up using in case anyone else wants to so something similar.
  DayMins = ((NumMins(sl.GetSetHour(), sl.GetSetMinute()))-(NumMins(sl.GetRiseHour(), sl.GetRiseMinute())));
  int duration = map((DayMins), 850, 615, 150, 60);
  InternalMemory.ActinicOffset_write(duration);
  InternalMemory.PWMSlopeDuration1_write(duration);
  InternalMemory.PWMSlopeDuration2_write(duration);
  InternalMemory.PWMSlopeDuration3_write(duration);
  InternalMemory.PWMSlopeDuration4_write(duration);
  InternalMemory.PWMSlopeDuration5_write(duration);
  ReefAngel.CustomVar[3]=duration;
In this scenario, ActinicOffset = Slope Duration.
On the longest day of the year my Actinic lights take 2.5 hours to ramp up to max and then the daylights turn on and take 2.5 hours to ramp up to max.
On the shortest day the Actinic lights take 1 hour to ramp to max and then the daylights turn on and take 1 hour to ramp to max.
I based these numbers on the attached spreadsheet factoring in MAX hours of day light vs. the Area under the curve in hopes to even out the strength vs. length of daylight swing in order to maintain actual sun rise and sun set times for my location.
lights curve.xlsx
Did you test it yet? Glad we came up with something :) curious if it works as designed
clw143
Post by clw143 »
It is up and running and functioning as intended.
Only time will tell if the coral enjoys it.
89delta
Post by 89delta »
Very cool. Now we can factor in seasonal shifts....
Sent from my Samsung Galaxy Note 3
clw143
Post by clw143 »
Tonight I observed that my controller is ramping the lights up to max and then back to where they belong. I'm not sure if it occurs all day or just during set. I only noticed because there was no lights on in the living room yet.
I suspect maybe there is something that needs to go infront or behind something else in my code. Below is my code, any help will be appreciated.
#include <SunLocation.h>
byte DailyAlk;
byte DailyCalc;
byte wp40mode; //Mode Byte
byte DayMins;
SunLocation sl;
  // Add Standard Menu
  ReefAngel.AddStandardMenu();
  ReefAngel.FeedingModePorts = Port3Bit | Port6Bit | Port7Bit| Port8Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.Relay.On( Port3 ); //Mag 12 Return Pump
  ReefAngel.Relay.On( Port4 ); //Reef Octopus Skimmer
  // initialize the sunrise / sunset location
  sl.Init(30.197220, -92.080637); // Latitude , Longitude values set (LA)
  sl.SetOffset(-5,0,-5,0); // rise_hour, rise_seconds, set_hour, set_seconds (LA)
  //Alkalinity Drip
   if (ReefAngel.Params.PH < 840) {
   ReefAngel.DosingPumpRepeat(Port1, 15,
         InternalMemory.DP1RepeatInterval_read(),
         InternalMemory.DP1Timer_read());
   //Calcium Drip
   ReefAngel.DosingPumpRepeat(Port2, 30,
         InternalMemory.DP2RepeatInterval_read(),
         InternalMemory.DP2Timer_read());
  //Cooling Fans
  ReefAngel.StandardFan( Port6 );
  //Ehiem 150W Heater
  //MAXI Jet 600 ATO Pump
  ReefAngel.StandardATO( Port8 );
  //Right & Left Philips Rebel ES Royal Blue and Cool White & UV & Cree XT-E Green
  ReefAngel.PWM.Channel1PWMSlope(InternalMemory.ActinicOffset_read());
  //Right Daylight Cree XP-G2 R5 Cool White
  ReefAngel.PWM.Channel2PWMSlope();
  //Right Actinic Cree XT-E Royal Blue
  ReefAngel.PWM.Channel3PWMSlope(InternalMemory.ActinicOffset_read());
  //Left Daylight Cree XP-G2 R5 Cool White
  ReefAngel.PWM.Channel4PWMSlope();
  //Left Actinic Cree XT-E Royal Blue
  ReefAngel.PWM.Channel5PWMSlope(InternalMemory.ActinicOffset_read());
  // handle updating sunrise and sunset values
  sl.CheckAndUpdate();
  //PWM Expansion Channels = 0 if Overheat or Lights off
  if ((ReefAngel.Params.Temp[T1_PROBE]>InternalMemory.OverheatTemp_read()) || (now()<sl.GetSunRise() || now()>sl.GetSunSet())) {
    ReefAngel.PWM.SetChannel (1,0);
    ReefAngel.PWM.SetChannel (2,0);
    ReefAngel.PWM.SetChannel (3,0);
    ReefAngel.PWM.SetChannel (4,0);
    ReefAngel.PWM.SetChannel (5,0);
  // moonlight are on between sunset hour and sunrise hour
  if (hour()>=sl.GetSetHour() || hour()<=sl.GetRiseHour()) ReefAngel.PWM.SetChannel (0, (map(MoonPhase(), 0,100,9.9,25)));
  else ReefAngel.PWM.SetChannel (0,0);
  //Start Feeding Mode at 17:00 (hour*60*60)
  if ( (now()%86400==61200) /*|| (now()%86400==39600) */) ReefAngel.FeedingModeStart();
  //Hydor Evolution 1400 Circulation Pump & LED Cooling Fan (Port5) Off Between sunrise hour and sunset hour
  if (hour()<sl.GetRiseHour() || hour()>=sl.GetSetHour())  {
    ReefAngel.Relay.Off(Port5);
  else {
    ReefAngel.Relay.On(Port5);
  ReefAngel.CustomVar[0]=DailyAlk;
  ReefAngel.CustomVar[1]=DailyCalc;
  DailyAlk = ((InternalMemory.DP1Timer_read() * (.75)) * (1440 / InternalMemory.DP1RepeatInterval_read()));    //Alk ml/day
  DailyCalc = ((InternalMemory.DP2Timer_read() * (.75)) * (1440 / InternalMemory.DP2RepeatInterval_read()));   //Calc ml/day
  //assignmenets are = and comparisons are ==
  if (ReefAngel.CustomVar[5] > 0){
    ReefAngel.PWM.SetDaylight( millis()%((10 * ReefAngel.CustomVar[6]))<((10 * ReefAngel.CustomVar[7]))?100:0); //Custom "W1"
    ReefAngel.PWM.SetActinic( millis()%((10 * ReefAngel.CustomVar[6]))>((10 * ReefAngel.CustomVar[6])-(10 * ReefAngel.CustomVar[7]))?0:100); //Custom "W1"
    wp40mode=10;
  }else{
  if (hour()>=sl.GetRiseHour() && hour()<12) wp40mode=6; //sunrise hour - 11:59am
    else if (hour()>=12 && hour()<17) wp40mode=7; //12pm - 4:59pm
    else if (hour()>=17 && hour()<18) wp40mode=5; //5pm - 5:59pm
    else if (hour()>=18 && hour()<24) wp40mode=3; //6pm - 11:59pm
  else wp40mode=4; //12am - sunrise hour
  if (wp40mode==9) ReefAngel.PWM.SetDaylight( 100 ); //Full Speed
  if (wp40mode==9) ReefAngel.PWM.SetActinic( 100 ); //Full Speed
  if (wp40mode==8) ReefAngel.PWM.SetDaylight( 100/3 ); //Third Speed
  if (wp40mode==8) ReefAngel.PWM.SetActinic( 100/3 ); //Third Speed
  if (wp40mode==7) ReefAngel.PWM.SetDaylight( millis()%1300<750?75:0); //Custom "W1"
  if (wp40mode==7) ReefAngel.PWM.SetActinic( millis()%1300>550?0:75); //Custom "W1"
  if (wp40mode==6) ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true ) ); //WaveMaxSpeed, PulseSync
  if (wp40mode==6) ReefAngel.PWM.SetActinic( TidalSwellMode(60,false ) ); //WaveMaxSpeed, PulseSync
  if (wp40mode==5) ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,75,2000,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==5) ReefAngel.PWM.SetActinic( NutrientTransportMode(0,75,2000,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==4) ReefAngel.PWM.SetDaylight( LongPulseMode(0,50,3,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==4) ReefAngel.PWM.SetActinic( LongPulseMode(0,50,3,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (s), PulseSync
  if (wp40mode==3) ReefAngel.PWM.SetDaylight( ShortPulseMode(0,65,1200,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==3) ReefAngel.PWM.SetActinic( ShortPulseMode(0,65,1200,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==2) ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true ) ); //WaveSpeed, WaveOffset, PulseSync
  if (wp40mode==2) ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false ) ); //WaveSpeed, WaveOffset, PulseSync
  if (wp40mode==1) ReefAngel.PWM.SetDaylight( SineMode(0,100,10,true ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==1) ReefAngel.PWM.SetActinic( SineMode(0,100,10,false ) ); //PulseMinSpeed, PulseMaxSpeed, PulseDuration (ms), PulseSync
  if (wp40mode==0) ReefAngel.PWM.SetDaylight( TideMode(20,100,20 ) ); //WaveSpeed, minOffset, maxOffset
  if (wp40mode==0) ReefAngel.PWM.SetActinic( TideMode(20,100,20 ) ); //WaveSpeed, minOffset, maxOffset
  //WP-40s off for water change
  if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetDaylight(0);
  if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
  ReefAngel.Portal( "clw143" );
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 3);
  ReefAngel.LCD.Clear(DefaultBGColor,0,25,132,33);
  ReefAngel.LCD.DrawText(0,255,18,14,"Jebao WP40 Mode:");
  if (wp40mode==0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,42,25,"Tide");
  else if(wp40mode==1) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,42,25,"Sine");
  else if (wp40mode==2) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE,255,23,25,"Reef Crest");
  else if (wp40mode==4) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,23,25,"Long Pulse");
  else if (wp40mode==3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,23,25,"Short Pulse");
  else if (wp40mode==5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,25,"Nutrient Trnsp.");
  else if (wp40mode==7) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,40,25,"W1");
  else if (wp40mode==6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,25,"Tidal Swell");
  else if (wp40mode==8) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,25,25,"1/3 Power");
  else if (wp40mode==9) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,23,25,"Full Power");
  else if (wp40mode==10) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,23,25,"W1 Test");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 34, 132, 34);
  ReefAngel.LCD.DrawText(0,255,10,37,"Disp");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 8, 45, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,53,37,"Room");
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 50, 45, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,95,37,"Sump");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 93, 45, text, Num8x8);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 53, 132, 53);
  ReefAngel.LCD.DrawText(0,255,10,56,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 27, 56, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,67,56,"WP40");
  ConvertNumToString(text, ReefAngel.PWM.GetDaylightValue(),1);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 95, 56, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,118,56," %");
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 65, 132, 65);
    char buf[16];
    sprintf(buf, "%02d:%02d", sl.GetRiseHour(), sl.GetRiseMinute());
    ReefAngel.LCD.DrawText(0,255,2,67,"Sun");
    ReefAngel.LCD.DrawText(0,255,21,67,"Rise: ");
    ReefAngel.LCD.DrawText(COLOR_BLUE,255,49,67,buf);
    sprintf(buf, "%02d:%02d", sl.GetSetHour(), sl.GetSetMinute());
    ReefAngel.LCD.DrawText(0,255,80,67,"Set: ");
    ReefAngel.LCD.DrawText(COLOR_BLUE,255,102,67,buf);
  ReefAngel.LCD.DrawText(0,255,8,75,"Moon: ");
  ConvertNumToString(text, MoonPhase(),1);
  ReefAngel.LCD.DrawText(COLOR_BLUE,255,40,75,text);
  ReefAngel.LCD.DrawText(0,255,58,75," %");
  ReefAngel.LCD.DrawText(0,255,28,83,MoonPhaseLabel());
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 92, 132, 92);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,7,96,"Shaun & Kerri's");
  ReefAngel.LCD.DrawLargeText(0,255,7,108,"90Gal Reef Tank");
  ReefAngel.LCD.DrawOutletBox(12, 118, TempRelay);
clw143
Post by clw143 »
So I commented out this
and the repeated ramping of lights during sun set stopped, the current duration stayed where it was in memory at 81 minutes for the 5 channels and for the ActinicOffset.
During ramping I could watch the % on the android app for output ramp up when I keep hitting the refresh button, the duration value I never observed a change in the custom variables. If I used the app to over ride the LED% the ramping stopped.
Any thoughts?
Verify the durations that are getting written to memory. Also you are writing to memory locations every iteration of your loop...this is a quick way to corrupt those memory locations. Do it once a day or only if the value differs
clw143
Post by clw143 »
What would be the best way for once per day? Just do the calculation and write the locations anytime after midnight?
if ( (now()%86400==00000) {
How would I add, if time = something or a reset was performed?
clw143
Post by clw143 »
Can I just go like this to get it to only write on a change?
    int S1 = (NumMins(sl.GetSetHour(), sl.GetSetMinute()));
    int S2 = (NumMins(sl.GetRiseHour(), sl.GetRiseMinute()));
    int DayMins = (S1-S2);
    int duration = map((DayMins), 615, 850, 60, 150);
    if (duration = duration){
    }else{
You can't compare duration with itself it will always be equal. Plus you are using = as assignment instead of comparison ==
I would change it to this:
if (duration!=ReefAngel.CustomVar[3]) {
