Can someone tell my why my lights aren't working?
MDB1029
Re: Can someone tell my why my lights aren't working?
Post by MDB1029 »
The jumpers are set to 0-5v and i did check it at the dimming expansion.
Disconnect the dimming wires and check the dimming expansion again.
MDB1029
Post by MDB1029 »
Copy of 20150812_121625.jpg (975.06 KiB) Viewed 8233 times
Looks correct. Disconnect the lead from channel 0 and check the DC voltage from there to the ground terminal. You shouldn't be getting any more than 5 volts and I want to isolate the dimming module from your dimmers to see where the extra voltage is coming from.
What lighting setup are you using, BTW?
MDB1029
Post by MDB1029 »
I am using a DIY build from RapidLED. LDD-1000H drivers: 2 ,LDD-650H drivers: 2, Power Supply: SE-350-48 , 4 x SemiLEDs True UV LEDs (400-410nm), 16 x CREE XP-G2 Cool White LEDs, 16 x CREE XT-E Royal Blue LEDs.
LDD-1000 for 8 CWs x 2
LDD-650 for 8 RB & 2 UV x 2
MDB1029
Post by MDB1029 »
11.25 from channel 0 to grd with no line going into channel 0.
Should I disconnect the drivers from the dimmer signal if it is sending this amount of voltage?
I really don't want/ can't replace them right now?
Yep, and PM Roberto to see if he has any ideas. I don't think the dimming module should be putting out 11.25v under any circumstances.
MDB1029
Post by MDB1029 »
I appreciate all your help.
FWIW, I accidentally had one of mine set to 10V for a period of time with no ill effects.
Let us know if you get it working.
Do you have any other expansion modules?
What kind of head unit are you using?
MDB1029
Post by MDB1029 »
I have no other expansion modules, only the wifi. I am using the RA Plus with PWM dimming
Can you open the case and verify that you have all 3 jumpers inside.
They should come by default, but it could have been missed.
Also, run the I2CScanner code and send the results:
http://forum.reefangel.com/viewtopic.php?p=18831#p18831
MDB1029
Post by MDB1029 »
3 jumpers are there
Took forever to get this done due to my shitbox computer but here it is:
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
Yeah, I don't see the module in the list.
I sent you a PM with the RMA #.
MDB1029
Post by MDB1029 »
Do i send the cables or just the expansion?
Just the module is fine
