Extended Lightning Effect
jallan258
Post by jallan258 »
Hi guys,
I was trying to get an extended lightning effect out of my code. Right now when the lightning does happen, It happens for about 3 seconds and then stops. Nothing happens after that except the reverse dimming process starts taking place again which is whats supposed to happen. I also notice that when the storm takes place both the Actinics and Daylights go from 0 - 100. I think I would like the Actinics to just stay at 100%. Any help would be appreciated. Here is the code I am using.
// Autogenerated file by RAGen (v1.1.0.126), (01/20/2012 20:04)
// RA_012012_2004.pde
#define DisplayImages
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
    ReefAngel.FeedingModePorts = B10001000;
    ReefAngel.WaterChangePorts = B10001000;
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    //Refugum Light/Moon Lights
    // LED Fans
    ReefAngel.StandardLights(3,10,30,22,00);
    ReefAngel.Wavemaker1(Port4);
    // Specific Programing for PWM Slope Drivers Actinic Port
    ReefAngel.StandardLights(5,10,30,22,00);
    // Specific Programming for PWM Slope Drivers Daylight Port
    ReefAngel.StandardLights(6,11,30,18,30);
 // PWM Slope in following format (hour on, minute on, hour off, minute off, Low Value Dim, High Value Dim, Time to reach Dim)
  // Calculate your regular sunrise/sunset PWM value
  ActinicPWMValue=PWMSlope(10,30,19,30,13,100,60,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(11,30,18,30,13,100,60,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 15
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,30)
#define End_Cloud_Before NumMins(17,30)
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Re: Extended Lightning Effect
This is the piece that handles the lightning.
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
Just remove the ActinicPWMValue and it will not change the actinics.
To increase the length of the lightning, use a greater number on second()<5
jallan258
Post by jallan258 »
Thanks I will try this in the morning.
jallan258
Post by jallan258 »
Works Perfectly thank you. One more question. Do you know if anyone coded a way to force the storm effect on demand? I keep searching through the forums but really haven't found the answer to that.
