I was trying to get an extended lightning effect out of my code. Right now when the lightning does happen, It happens for about 3 seconds and then stops. Nothing happens after that except the reverse dimming process starts taking place again which is whats supposed to happen. I also notice that when the storm takes place both the Actinics and Daylights go from 0 - 100. I think I would like the Actinics to just stay at 100%. Any help would be appreciated. Here is the code I am using.
// Autogenerated file by RAGen (v1.1.0.126), (01/20/2012 20:04)
// RA_012012_2004.pde
#define DisplayImages
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ReefAngel.FeedingModePorts = B10001000;
ReefAngel.WaterChangePorts = B10001000;
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1);
//Refugum Light/Moon Lights
// LED Fans
ReefAngel.StandardLights(3,10,30,22,00);
ReefAngel.Wavemaker1(Port4);
// Specific Programing for PWM Slope Drivers Actinic Port
ReefAngel.StandardLights(5,10,30,22,00);
// Specific Programming for PWM Slope Drivers Daylight Port
ReefAngel.StandardLights(6,11,30,18,30);
// PWM Slope in following format (hour on, minute on, hour off, minute off, Low Value Dim, High Value Dim, Time to reach Dim)
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(10,30,19,30,13,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(11,30,18,30,13,100,60,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 15
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,30)
#define End_Cloud_Before NumMins(17,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
