water change build
Re: water change build
ok. I think I know the answer to that one.. :) a little back to the drawing board. One moment.
//Waterchange Mode
  static time_t wc_drain=0;
  static time_t wc_tankoff=0;
  static time_t wc_tankup=0;
  static time_t wc_refill=0;
  static int stage=0;
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0 && second()==0))
  {   // At 6pm every day the following to occur or when WC mode is activated
    wc_tankoff=now();
    stage=1;
  if (now()-wc_tankoff < 300 && stage==1)
    ReefAngel.Relay.Off(Box1_Port7);
    ReefAngel.Relay.Off(Box1_Port8);
  } else {
    wc_drain=now();
    wc_tankoff=0;
    stage=2;
  if (now()-wc_drain < 300 && stage==2)
    ReefAngel.Relay.On(Box1_Port4);
    ReefAngel.Relay.Off(Box1_Port4);
  } else {
    wc_tankup=now();
    wc_drain=0;
    stage=3;
  if(now()-wc_tankup < 300 && stage==3)
    ReefAngel.Relay.On(Box1_Port8);
  } else {
    wc_refill=now();
    wc_tankup=0;
    stage=4;
 if (now()-wc_refill < 300 && stage==4)
    if (ReefAngel.HighATO.IsActive()) wc_refill=0;
  } else {
    ReefAngel.Relay.Off(Box1_Port1);
    //ButtonPress++;
    wc_refill=0;
    stage=0;
tyson_mitchell_88
Post by tyson_mitchell_88 »
Everything is on on start up.
What is everything? Doesn't make sense for Box1_Port1 to be on? I would add a ReefAngel.Relay.Off(Box1_Port1); before the water change section to make sure it's set to off and for Box1_Port4 also**
Should also change this : if (ReefAngel.HighATO.IsActive()) wc_refill=0;
to
    if (ReefAngel.HighATO.IsActive()) { wc_refill=0; stage=0 };
tyson_mitchell_88
When I upload
>port 7 & 8 are on
>port 4 is also on
>If I toggle float switch port 4 turns off, port 1 turns on
I changed the wc_refill high ato to just work like the first as well.
#include <Moon.h>
//Standard Dimming//
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
//Dimmer Expansion//
byte WhitePWMValue=0;
byte Actinic1PWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
    InternalMemory.LCDID_write(0);
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Box1_Port6);
    ReefAngel.StandardHeater( Port2,220,225 );
    ReefAngel.StandardLights( Port3,8,00,16,00);
    ReefAngel.StandardFan   ( Port4,230,238 );
    ReefAngel.StandardLights( Port7,21,00,5,00 );
    ReefAngel.StandardLights( Port8,5,00,21,00 );
    ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//White off
  if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
    ReefAngel.Relay.Off(Port8);
  } else {
//Display in Failsafe//
//boosterpump//
      ReefAngel.Relay.Off(Box1_Port2);
      ReefAngel.Relay.On(Box1_Port2);
//Lighting Control//
    ActinicPWMValue=PWMSlope(5,00,21,00,0,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
    WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
    Actinic1PWMValue=PWMSlope(5,00,21,00,0,80,180,Actinic1PWMValue);
    SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
    MoonPWMValue=PWMSlope(21,00,5,00,0,MoonPWMValue,235,0);
    CheckCloud();
//Lighting expansion control//
    ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
    ReefAngel.PWM.SetChannel( 1, Actinic1PWMValue);
    ReefAngel.PWM.SetChannel( 2, SupPWMValue);
    ReefAngel.PWM.SetChannel( 3, SupPWMValue);
    ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
    ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
//Waterchange Mode
  static int stage=0;
    wc_tankoff=now();
    stage=1;
  } else {
    wc_drain=now();
    wc_tankoff=0;
    stage=2;
  } else {
    wc_tankup=now();
    wc_drain=0;
    stage=3;
  } else {
    wc_refill=now();
    wc_tankup=0;
    stage=4;
    } else {
    //ButtonPress++;
    wc_refill=0;
    stage=0;
    ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
  // In this example, start cloud after noon
#define Start_Cloud_After NumMins(6,30)
#define End_Cloud_Before NumMins(18,30)
#define Lightning_Change_per_Cloud 60
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
   static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      WhitePWMValue=DaylightPWMValue;
      MoonPWMValue=DaylightPWMValue;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  byte n;
  int newdata;
  byte a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (byte i=0; i<a; i++)
    // Flash on
    analogWrite(daylightPWMPin,255);    // Flash on daylight port
    newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
    newdata=ReefAngel.PWM.GetChannelValue(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    Wire.write(0x8+(4*1));
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
Full script just encase I have something out of place.
Last edited by tyson_mitchell_88 on Sat Jan 23, 2016 7:10 am, edited 3 times in total.
tyson_mitchell_88
Float switches are function for the ports now to. Not sure why it is all triggering straight away though.
Port 1 is not on when I upload but if I move the float switch it turns on. Realised a mistake that i just changed.
You may need to start adding some Serial.println("step1"); type messages to see whats going on. You can also do Serial.println(wc_tankoff); to see a variable value. Notice the quotes. Then you can monitor in Serial Monitor to troubleshoot
tyson_mitchell_88
I will have to have a look into it, haven't done any serial monitoring yet. The code we have makes sense that it should work. Not sure why the modes are triggering early.
tyson_mitchell_88
Lee what about if we tried a different approach like this?
//Waterchange Mode
  static time_t wcTimer=0;
  static int stage=0;
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE);
    wcTimer=now();
   if (now()-wcTimer >= 1 && now()-wcTimer < 600)
    if (now()-wcTimer >= 60 && now()-wcTimer < 120)
    if (now()-wcTimer >= 120 && now()-wcTimer < 180)
    if (!ReefAngel.HighATO.IsActive())
//   } else {
//    ButtonPress++;
Its compiling but not activating on when I turn on waterchange mode.
Put in the waterchange code a test that wc_timer == 0 and in the final else make sure you reset it to 0.
Right now every pass it is setting wc_timer to now and so now()-wc_timer is always going to equal 0 and so it will never trigger anything else.
Otherwise the code looks good. But I'm not having a good track record here.
tyson_mitchell_88
I wasn't exactly sure where to put wcTimer==0, sorry mate.
//Waterchange Mode
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE && wcTimer==0);
    wcTimer=now();
   if (now()-wcTimer >= 1 && now()-wcTimer < 120)
   } else {
    wcTimer=0;
//    ButtonPress++;
Looks right to me
tyson_mitchell_88
Still not triggering on waterchange. I know its a silly question but I'm using the android app to activate not the RA, would this have any effect?
tyson_mitchell_88
Here is my full build encase something is out of the ordinary and causing problems.
#include <Moon.h>
byte SupPWMValue=0;
//    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
//    ReefAngel.AddORPExpansion();  // ORP Expansion Module
// Default Ports
    ReefAngel.Relay.On(Port1); //Sump Skimmer
    ReefAngel.Relay.Off(Box1_Port1); //Sump Out
    ReefAngel.Relay.On(Box1_Port6); //Sump Light
    ReefAngel.Relay.Off(Box1_Port4); //Sump Out
// Place additional initialization code below here
// Place additional initialization code above here
    ReefAngel.StandardHeater(Port2,220,225); //Sump Heater
    ReefAngel.Relay.Set(Port3,ReefAngel.PWM.GetChannelValue(2)>0); //Sup Power
    ReefAngel.StandardFan(Port4,230,238); //Chiller
    ReefAngel.Relay.Set(Port7,ReefAngel.PWM.GetChannelValue(4)>0); //Moon Power
    ReefAngel.Relay.Set(Port8,ReefAngel.PWM.GetChannelValue(1)>0); //White / Blue Power
    ReefAngel.StandardLights( Box1_Port5,8,00,16,00 ); //Display Color
    ReefAngel.Relay.On(Box1_Port7); //4FT In
//Sump out
    if (ReefAngel.Relay.isMaskOn(Box1_Port4) && !ReefAngel.HighATO.IsActive())
    ReefAngel.Relay.Override(Box1_Port4,0);
//Salt In
    if (ReefAngel.Relay.isMaskOn(Box1_Port1) && ReefAngel.HighATO.IsActive())
    ReefAngel.Relay.Override(Box1_Port1,0);
//White off
  } else {
//Boosterpump//
// Turn off Air Pump if Skimmer has been shutoff
    if (ReefAngel.Relay.Status(Port1)>0)
      ReefAngel.Relay.Off(Port6);
    ActinicPWMValue=PWMSlope(5,00,21,00,10,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,10,70,180,DaylightPWMValue);
    Actinic1PWMValue=PWMSlope(5,00,21,00,2,80,180,Actinic1PWMValue);
    MoonPWMValue=PWMSlope(21,00,5,00,1,MoonPhase(),235,0);
    CheckCloud();
//Waterchange Mode
    wcTimer=now();
   } else {
    wcTimer=0;
//    ButtonPress++;
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
      //MoonPWMValue=DaylightPWMValue;
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      int x=0;
      else x=17;
      else x=35;
      int x=0;
      else x=57;
      else x=75;
void Strike()
  byte n;
  int newdata;
    // Flash on
    newdata=4095;
  cstart*=60;
  cend*=60;
I dont see anything that would conflict with it, very frustrating I'm sure. Stick in there. Roberto what are we missing?
>Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
What do you mean with this?
What is the 10 minutes? If box1 port 4 is activated as soon as water change is triggered and stops when float switch is off, what is the 10 minute for?
tyson_mitchell_88
Ports 7 & 8 are my returns. I need them to turn off, then box 1 port 4 drains the sump untill HighATO is off. I need the time delay so the water can backflow from the tanks.
Try this:
    static byte status=255;
    static int LastDisplayedMenu=-1;
    if (LastDisplayedMenu!=WATERCHANGE_MODE && ReefAngel.DisplayedMenu==WATERCHANGE_MODE) status=0;
    LastDisplayedMenu=ReefAngel.DisplayedMenu;
      if (status==0)
          status=1;
      if (status==1)
          ButtonPress++;
          status=255;
And I was using this to display the boxes and status variable when on water change:
        ReefAngel.LCD.DrawText(0,255,10,70,status);
        static byte OldTempRelay=0;
	if (TempRelay!=OldTempRelay)
		OldTempRelay=TempRelay;
		ReefAngel.LCD.DrawOutletBox(12, 80, TempRelay);
tyson_mitchell_88
Its not activating. status flag on the app is showing waterchange mode on, nothing changes though.
tyson_mitchell_88
I have a question with how this script is working
          status=1;
Once HighATO stops being active will it change straight to the next stage?
I need the switch to function, switching on and off, over a time period so it can drain all of the water from the sump. It can take a while for the tanks to finish draining.
Same with Box1_pPort1, which pumps water into the sump a lot faster then my return pumps.
Probably because your float switches are not as you are stating it to be in the original post.
It needs to stay in status 0 until ATOHigh is not active.
If ATOHigh is already not active when you enter water change mode, it will go straight into status 1 and you won't see anything change.
So, there must be something wrong with the way your float was described.
I'm not following what you are saying.
If box1 port1 pumps water out, it will stay pumping until the float is triggered. You don't need time here because what changes status is the float being triggered and not time.
Unless you are not describing what you want correctly.
I'm very confused what you are trying to do and how you want to do it.
I think it will be easier if you draw a flowchart of what you want and explain exactly how many status and how the statuses advances to next one and what happens in each status phase.
tyson_mitchell_88
I understand what you mean with the float switch, sorry for not being more clear.
>Activate when waterchange mode on
>Ports 7 & 8 turn off
>water drains from the tanks into the sump (stage 1)
>port 4 is on when HighATO is on (stage 2)
>water may still be draining from the tanks so the float switch may turn off
>if the float switch turns off and goes instantly to the next stage water could still be draining from the tanks
>maybe this could only activate after a certain time from stage 1, allowing the tanks to drain
>the float switch could potentially already be in the off position
>Ports 7 & 8 turn on (stage 3)
>port1 is on when HighATO is off
>this pumps water into the sump a lot faster then the returns can get it up, which will switch the HighATO on and end, leaving my sump short of water
If I had the money I would get a water level expansion, I'm just trying to use what i have available. Is there a way to run float switches off the second power board?
Ok, so you need a time delay for stage 2 where the float status is only checked after a certain amount of time?
Same for stage 3?
tyson_mitchell_88
A delay will work after port 7 & 8 are turned off.
Not sure with the refill as the switch will need to toggle.
A delay after ports 7 & 8 are on will result in my sump running dry. If then the process ends when HighATO is on the sump won't get enough water to fill the tanks. As I said port 1 pumps water into the sump alot faster then ports 7 & 8 can pump it into the tanks
tyson_mitchell_88
This is why in the original post I wanted the float switch process (being able to turn on and off) to run over a time period. Ensuring all water gets out and enough can be pumped back in
I still don't follow the run over time you mention.
A float switch is either active or not active and it can't be over time.
It changes from active to not active in a split of a second.
tyson_mitchell_88
Can we make it so it only changes to the next step if the float switch has changed state for a certain time?
I understand the float switch changes instantly but if it does this and ends the process for port 1, the return pumps will run dry. The return pumps will not pump water up into the tanks faster then port 1 can pump water into the sump. Not sure how to explain this anymore mate
Ahhh. now I get it.
tyson_mitchell_88
Good to hear mate. Will it be possible to code?
