Icecap Module
Ismaclst
Re: Icecap Module
Post by Ismaclst »
Here is my latest code:
#include <Tide.h>
Tide tide;
  ReefAngel.DDNS("Damien");
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port3Bit;
  ReefAngel.Relay.Set(Port8, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN);
  InternalMemory.WaterLevelMax_write(1800);
  tide.Init(55,10,30);
  tide.SetWaveLength(12+SECS_PER_HOUR);
  ReefAngel.StandardHeater( Port3,780,785 );
  ReefAngel.WaterLevelATO(4,Port4,240,28,31);
  if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
    ReefAngel.Relay.Override(Port8,0);    //Saltwater Reservoir
  if (ReefAngel.WaterLevel.GetLevel(1)>80)   // Set port back to auto
    ReefAngel.Relay.Override(Port8,2);
  if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.On(Port1);
  if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
    ReefAngel.Relay.Off(Port5);
  if (ReefAngel.WaterLevel.GetLevel(3)<1)
    ReefAngel.Relay.On(Port5);
  ReefAngel.Portal( "Ismaclst" );
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
  int reverse_speed=0;
  int forward_speed=45;
   // swap between forward and reverse every X seconds
   reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
   if (reverse_speed == 100) {
     // while we are going in reverse increase the speed by 10
     forward_speed = ShortPulseMode(35+10, 60+10,ReefAngel.DCPump.Duration,true);
   } else {
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(35,70, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
    return forward_speed;
  } else {
    return reverse_speed;
Re: Icecap Module
You added the function but you have to call it. Same with the tide you set. We have to tie them together now.
You need to add the following now to set your dimming channels.
I need to be on the computer to give you the right code. I also made some mistakes that I need to fix in the setMaspect function.
Ismaclst
Re: Icecap Module
Post by Ismaclst »
I bought a stereo audio cable for forward and reverse. How many wires should be in it? I cut the end off and there are three, a red, blue and white.
Re: Icecap Module
One should be ground and the other two would be for your two signals. If you are wiring to the dimming leads you'll share the ground.
Ismaclst
Re: Icecap Module
Post by Ismaclst »
lnevo wrote:You added the function but you have to call it. Same with the tide you set. We have to tie them together now.
Did you ever get a chance to look into this more?
Re: Icecap Module
No, i got swamped this weeken. I'll probably have a chance friday if you can hang in...
Ismaclst
Re: Icecap Module
Post by Ismaclst »
No problem
Re: Icecap Module
Ok, this should do it. I've set the min speed to 1/2 the Tidal speed and used the Tidal speed as the max speed. As discussed the tidal speed will vary +/- depending on the range you gave which means 55 (+/-5 during quarter moons and half moon, versus +/-15 during newmoon and full moon) It will also vary throughout the day based on the wavelength you have set.. which is currently 72 minutes... tide.SetWaveLength(12+SECS_PER_HOUR); The default is 12 hours which would be 12*SECS_PER_HOUR. Anyway below is the code that will set the Actinic/Daylight to the value of the the setMaxspect function using the tide class as an input. I also included the change I made in your RO/Valve post
#include <Tide.h>
Tide tide;
  ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
  ReefAngel.Relay.Off(Port5); // Set Default to off
  ReefAngel.PWM.SetDaylight(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,true)); // Set the Speed
  ReefAngel.PWM.SetActinic(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,false)); // Set the direction - speeds here are irrelevant actually.
     forward_speed = ShortPulseMode(minSpeed+10, maxSpeed+10,ReefAngel.DCPump.Duration,true);
   } else {
     forward_speed = ShortPulseMode(minSpeed,maxSpeed, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
  } else {
Ismaclst
Re: Icecap Module
Post by Ismaclst »
Thanks for taking the time and correcting my code. I appreciate it.
slm222
Re: Icecap Module
Post by slm222 »
I know this is an old thread. But I wanted to check before moving forward. Icecap just came out with their gyre pump as a license off maxspect. If i get their gyre pump and the ice cap module will this work with the DC pump codes? i current have two jeabo but would like to swap out to two opposing gyres. I have the jebaos set up to randomly select the wave pattern for the day. would this still be relevant for the gyre control? along with feed mode?
Re: Icecap Module
I don't see why not.
It should work just the same.
