#include <Tide.h>
Tide tide;
ReefAngel.DDNS("Damien");
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.Relay.Set(Port8, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN);
InternalMemory.WaterLevelMax_write(1800);
tide.Init(55,10,30);
tide.SetWaveLength(12+SECS_PER_HOUR);
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.WaterLevelATO(4,Port4,240,28,31);
if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
ReefAngel.Relay.Override(Port8,0); //Saltwater Reservoir
if (ReefAngel.WaterLevel.GetLevel(1)>80) // Set port back to auto
ReefAngel.Relay.Override(Port8,2);
if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.On(Port1);
if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
ReefAngel.Relay.Off(Port5);
if (ReefAngel.WaterLevel.GetLevel(3)<1)
ReefAngel.Relay.On(Port5);
ReefAngel.Portal( "Ismaclst" );
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
int reverse_speed=0;
int forward_speed=45;
// swap between forward and reverse every X seconds
reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
if (reverse_speed == 100) {
// while we are going in reverse increase the speed by 10
forward_speed = ShortPulseMode(35+10, 60+10,ReefAngel.DCPump.Duration,true);
} else {
// while we are going forward set speed to 25-40 to keep
// from blowing corals off the rocks
forward_speed = ShortPulseMode(35,70, ReefAngel.DCPump.Duration, true);
if (PulseSync) {
return forward_speed;
} else {
return reverse_speed;
