internal web page no longer working?
Smotz
Post by Smotz »
'Lo - is the internet web portal working?
192.168.0.13:2000/wifi
I add my controller
Then when I click refresh it tells me it is unable to process data..?
Any thoughts?
Smotz
Re: internal web page no longer working?
Post by Smotz »
Is there any more support ?
Can you send screenshot?
Smotz
Post by Smotz »
I get the error in ra1.jpg no matter if I enter in the public or private IP
Ok, try this.
If you are using the internal Uapp from ipaddress:2000/wifi, please delete the profile and leave it without any profile.
Refresh that page.
You should see an image without any controller shown in the middle top bar.
Now, hit refresh.
Does it work?
Smotz
Post by Smotz »
rimai wrote:Ok, try this.
Refresh that page.
Now, hit refresh.
Does it work?
Unfortunately, no. Same error.
Do you have authentication setup for your internal webserver?
Smotz
Post by Smotz »
I do. It authenticates and allows me to the main page.
That's the problem. Uapp will not connect to it :(
Smotz
Post by Smotz »
rimai wrote:That's the problem. Uapp will not connect to it :(
Wont work at all? Any roadmap to make it work?
Post an issue on the github to request this.
https://github.com/reefangel/U-App-2.0
If you want to look through the code and help us implement, it would be awesome :)
The entire UApp is built in HTML5 and javascript.
Smotz
Post by Smotz »
rimai wrote:Post an issue on the github to request this.
Cool, thx. Will do.
saf1
Post by saf1 »
So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
Smotz
Post by Smotz »
saf1 wrote:So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
exactly. apparently if you use authentication on the internal web page, it won't work.
