ReefAngel.DCPump.AntiSyncOffset=85;
how would I use this and where would I put it in my code?
thanks
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port4, 19,0,7,0); //Skimmer, Reactor 7pm-7am
ReefAngel.StandardLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
// DC pumps
// To run this code must choose Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%600==0 || changeMode==true) { // Change every 10 mins (600seconds) or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800) {
// Night mode (go to 30%)
} else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11am / 11pm
ReefAngel.DCPump.Mode=Gyre;
ReefAngel.DCPump.Speed=30;
} else {
