2 different size jebao pumps
Reefology
Post by Reefology »
I assume the following line of code is to offset water volume of different pumps but not exactly sure?
ReefAngel.DCPump.AntiSyncOffset=85;
how would I use this and where would I put it in my code?
thanks
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardLights( Port4, 19,0,7,0); //Skimmer, Reactor 7pm-7am
    ReefAngel.StandardLights( Port5 );
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%600==0 || changeMode==true) { // Change every 10 mins (600seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800) {
    // Night mode (go to 30%)
    } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11am / 11pm
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=30;
Re: 2 different size jebao pumps
You can run it in loop or in setup and it will set the percentage for the pump you set as AntiSync. So that one will go at 85% of the speed of the primary.
Reefology
Post by Reefology »
thanks for the reply Lee. can I change it to
ReefAngel.DCPump.SyncOffset=85;
if the primary is the bigger pump? Or
ReefAngel.DCPump.AntiSyncOffset=115; ?
Reefology
Post by Reefology »
thanks Lee, found the thread
http://forum.reefangel.com/viewtopic.ph ... SyncOffset
will link it here for others.
thanks
Reefology wrote:thanks for the reply Lee. can I change it to
I think you can do that as well. It just makes that a percentage and multiplies it against the sync pump's speed.
