Help to new USB - TTL
tafarifilho
Post by tafarifilho »
Hi.
I lost my USB cable. I'm from Brazil, and 55$ only for shipping, is very expensive.
The board is v 6.1
And the Ftdi Ft232r Adapter Ttl to Arduino Mini Esp8266
Could someone help me order the wiring?
Tks.
tafarifilho
Re: Help to new USB - TTL
This site is valid?
https://upverter. com/reefangel/
tafarifilho
Is this connection correct?
Yes.
tafarifilho
Roberto, Thanks for the answer.
But... :)
The wires are connected as I said above. (See the picture).
In Arduino 1.0.1, I chose "Reef Angel Controller" motherboard.
Serial Port: COM3.
When I try to compile and upload CustomMainScreen_AquaIllumination, for test, i received the error:
stk500_getsync(): not in sync: resp=0x12
Thank you for all the help you get.
Sorry....
Actually it is GND-X-X-TX-RX-RTS or DTR
https://learn.sparkfun.com/tutorials/sp ... -guide/all
tafarifilho
After much pain in trying to manually mount the cable, I gave up and bought a new cable on the site.
But, and there is always a "but" ...
The new USB-TTL Converter Cable does not work or I do not know how to get it to work.
What is the correct way to connect it?
Look in the manual.
