Hi.
I lost my USB cable. I'm from Brazil, and 55$ only for shipping, is very expensive.
The board is v 6.1
And the Ftdi Ft232r Adapter Ttl to Arduino Mini Esp8266
Could someone help me order the wiring?
Tks.
Help to new USB - TTL
- Image
- ezgif.com-webp-to-jpg.jpg (66.26 KiB) Viewed 10644 times
- Image
- 20190504_124128.jpg (346.33 KiB) Viewed 10644 times
- Image
- 20190504_122745.jpg (312.43 KiB) Viewed 10644 times
Re: Help to new USB - TTL
Is this connection correct?
- Image
- ReefAngel.png (871.11 KiB) Viewed 10628 times
Roberto, Thanks for the answer.
But...
The wires are connected as I said above. (See the picture).
In Arduino 1.0.1, I chose "Reef Angel Controller" motherboard.
Serial Port: COM3.
When I try to compile and upload CustomMainScreen_AquaIllumination, for test, i received the error:
stk500_getsync(): not in sync: resp=0x12
Thank you for all the help you get.
But...
Serial Port: COM3.
- Error
- 20190506_000809.jpg (155.35 KiB) Viewed 10615 times
- Wires
- 20190506_000530.jpg (254.56 KiB) Viewed 10615 times
Sorry....
Actually it is GND-X-X-TX-RX-RTS or DTR
https://learn.sparkfun.com/tutorials/sp ... -guide/all
After much pain in trying to manually mount the cable, I gave up and bought a new cable on the site.
But, and there is always a "but" ...
The new USB-TTL Converter Cable does not work or I do not know how to get it to work.
What is the correct way to connect it?
- 20190605_014448.jpg (202.39 KiB) Viewed 10519 times
