JBJ Unibody controllable with RA basic
miked
Post by miked »
I have a JBJ unibody dimmable fixture that states is is compatible with 3rd party controllers. anybody have any knowledge if it will work with the RA? I tried to attach a link to the .pdf manual (not ok). but if you google JBJ unibody manual it is the firs thing up. light has already been purchased.
thanks
miked
Re: JBJ Unibody controllable with RA basic
Post by miked »
It uses the Duo 700 driver if that helps.
Thank you
Prettu sure it uses analog signal, so you will need the PWM-to-Analog lead wire.
miked
Post by miked »
yes, I found that it has 2 analog control ports at 2.1mm. Do you sell the PWM to analog lead wire to fit a 2.1mm jack?
No. You would have to patch your own cable.
miked
Post by miked »
ok thanks
