I have a JBJ unibody dimmable fixture that states is is compatible with 3rd party controllers. anybody have any knowledge if it will work with the RA? I tried to attach a link to the .pdf manual (not ok). but if you google JBJ unibody manual it is the firs thing up. light has already been purchased.
thanks
JBJ Unibody controllable with RA basic
Re: JBJ Unibody controllable with RA basic
Prettu sure it uses analog signal, so you will need the PWM-to-Analog lead wire.
yes, I found that it has 2 analog control ports at 2.1mm. Do you sell the PWM to analog lead wire to fit a 2.1mm jack?
