Hi All,
Can anyone give me some pointers on how to achieve the following, for reference I have the older RA+ with the RF module to control the older MP ES pumps;
I would like to either add a new submenu or rename and use the Water change menu to perform the following:
Set MP40s to Constant speed
Turn on a relay port
thanks
Andy
Adding a new menu
- Contact:
Re: Adding a new menu
check out the Custom Menu Generator thread. it's under the Software section and then Apps and the topic is Sticky. I can't link to it from my phone. You would have to create your own menu but can do it.
let me know if you need more help.
Sent from my Pixel 2 using Tapatalk
- Contact:
Here's the link to the thread.
https://forum.reefangel.com/viewtopic.php?f=8&t=1773
Appleseed
