Wifi Issues.. again
nevets9333
Wifi Issues.. again
Post by nevets9333 »
Hello-
My Reef Angel Star has been running for a few years. I had to move my aquarium and the Star was unplugged for a couple of weeks. When I plugged back in, I couldn't get it connected to the app or portal. It is plugged into an ethernet cable. I tried regenerating a new basic code with the wizard to at least get it up an running again, but the Star still says disconnected. Any help is appreciated!
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
    ReefAngel.Star();
    ReefAngel.FeedingModePortsE[1] = 0;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[1] = 0;
    ReefAngel.LightsOnPortsE[1] = 0;
    ReefAngel.Relay.On( Box2_Port1 );
    ReefAngel.Relay.On( Box2_Port2 );
    ReefAngel.Relay.On( Box2_Port5 );
    ReefAngel.Relay.On( Box2_Port6 );
    ReefAngel.Relay.On( Box2_Port7 );
    ReefAngel.Relay.On( Box2_Port8 );
    ReefAngel.StandardHeater( T1_PROBE,Box1_Port3,755,770 );
    ReefAngel.StandardHeater( T1_PROBE,Box2_Port3,755,0 );
    ReefAngel.StandardHeater( T1_PROBE,Box1_Port4,760,775 );
    ReefAngel.StandardHeater( T1_PROBE,Box2_Port4,760,0 );
    boolean buzzer=false;
    if ( ReefAngel.isOverheat() ) buzzer=true;
    ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX1+F+SK+rrZYH8vnept+Gb+fxxRoP8+yOIk=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT16=Port 16
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT15=Port 15
// RA_LABEL LABEL_PORT24=Heater
// RA_LABEL LABEL_PORT28=Port 28
// RA_LABEL LABEL_PORT23=Heater
// RA_LABEL LABEL_PORT14=Heater 76-775
// RA_LABEL LABEL_PORT13=Heater 755-77
// RA_LABEL LABEL_PORT18=Port 18
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT11=Port 11
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT12=Port 12
// RA_LABEL LABEL_PORT17=Port 17
// RA_LABEL LABEL_PORT21=Port 21
RA Star.png (247.19 KiB) Viewed 7292 times
nevets9333
Re: Wifi Issues.. again
Anyone have an idea on what to do?
brennyn21
Post by brennyn21 »
Can you plug the ethernet cable into a laptop or other device to verify the router or switch is working?
Sincerely, Brennyn
nevets9333
brennyn21 wrote:Can you plug the ethernet cable into a laptop or other device to verify the router or switch is working?
Thank you for responding!
Yes I tried that. Has internet connection when plugged into laptop!
brennyn21
Post by brennyn21 »
2 things to try is doing a full power reboot, not rebooting from the menu screen if that doesn't work. I suggest try changing the time on the controller to match the current time, then reboot from the controller from the menu screen.
Sincerely, Brennyn
nevets9333
brennyn21 wrote:2 things to try is doing a full power reboot, not rebooting from the menu screen if that doesn't work. I suggest try changing the time on the controller to match the current time, then reboot from the controller from the menu screen.
Yea I tried both those but no luck. I don't understand why the controller isn't showing an ip adress..
brennyn21
Post by brennyn21 »
Can you login to your router and see if its getting an IP addresss?
Sincerely, Brennyn
nevets9333
I was trying to get this figured out before I went away, but was not able to. I wouldn't be able to check until my return at the end of the month I know how to log into my router, but how wouldI be able to tell if that is specifically getting an ip?
brennyn21
Post by brennyn21 »
Sorry for the late reply hopefully you were able to get it resolved. if not you should have something called a DHCP Leases or dhcp list and that should show you a list of devices with IP address
Sincerely, Brennyn
