HOW WOULD I GO ABOUT EDITING THE.....
ReefAngel_CustomColors.h file
AM WANTING TO CHANGE THE OUTLET BOX COLORS TO SOMETHING OTHER THAN THE DEFAULT OFF = RED AND ON = GREEN
EDIT COLOR FILE?
Re: EDIT COLOR FILE?
So you would need to install Arduino onto your PC install the libraries and then modify the libraries. Other option is to use a custom function, which I'll show below.
So in the Global Variables first place this below to define the colors used for the outlets.
Now you will want to replace this line of your original code
Original
The line above should be replaced with this line below
Now place this below the void loop.
Now you can modify the define statements to the color of your liking.
#define OutletOnBGColor COLOR_GREEN // Outlet On Background Color
#define OutletOnFGColor COLOR_WHITE // Outlet On Font Color
#define OutletOffBGColor COLOR_RED // Outlet Off Background Color
#define OutletOffFGColor COLOR_WHITE // Outlet Off Font Color
Original
ReefAngel.LCD.DrawOutletBox(12, 85, TempRelay);
DrawCustomOutletBox(12, 85, TempRelay);
void DrawCustomOutletBox(byte x, byte y,byte RelayData)
ReefAngel.LCD.Clear(OutletBorderColor,x,y,x+104,y); //94
ReefAngel.LCD.Clear(OutletBorderColor,x,y+12,x+104,y+12);
for (byte a=0;a<8;a++)
byte bcolor = OutletOffBGColor;
byte fcolor = OutletOffFGColor;
char temp[]=" ";
if ((RelayData&(1<<a))==1<<a)
bcolor = OutletOnBGColor;
fcolor = OutletOnFGColor;
ReefAngel.LCD.Clear(bcolor,x+(a*13),y+1,x+13+(a*13),y+11);
itoa(a+1,temp,10);
ReefAngel.LCD.DrawText(fcolor,bcolor,x+4+(a*13),y+3,temp);
Sincerely, Brennyn
OK I TRIED AND I GET THE BELOW ERROR.....
Compilation failed for CASPAR.ino: Details: CASPAR.ino: In function 'void DrawCustomMain()': CASPAR.ino:117:1: error: 'DrawCustomOutletBox' was not declared in this scope CASPAR.ino:117:1: note: suggested alternative: 'DrawCustomGraph' CASPAR.ino: In function 'void loop()': CASPAR.ino:236:1: error: a function-definition is not allowed here before '{' token
BELOW HERE IS THE CODE I TRIED......
const char menu1_label[] PROGMEM = "Feeding Mode";
const char menu2_label[] PROGMEM = "Water Change Mode";
const char menu3_label[] PROGMEM = "Cloud On Demand";
const char menu4_label[] PROGMEM = "Clear ATO Timeout";
const char menu5_label[] PROGMEM = "Set Clock";
const char menu6_label[] PROGMEM = "Calibrate pH";
const char *const menu_items[] PROGMEM = {
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
#define OutletOnBGColor COLOR_BLUE // Outlet On Background Color
#define OutletOnFGColor COLOR_BLACK // Outlet On Font Color
#define OutletOffBGColor COLOR_WHITE // Outlet Off Background Color
#define OutletOffFGColor COLOR_BLACK // Outlet Off Font Color
byte DaylightPWMValue=0;
boolean ForceCloud=false;
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
byte x = 6;
byte y = 2;
byte t;
// Parameters
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_INDIGO, 1, 11, 132, 11);
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 102, "----------------------");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 126, "----------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,14,40,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 50, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,99,40,"PH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 50, text, Num8x16);
// Main Relay Box
DrawCustomOutletBox(12, 101, TempRelay);
ReefAngel.LCD.DrawText(COLOR_RED,255,14,63,"SUMP");
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,92,63,"ROOM");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,10,110, "White");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 32, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_RED,255,90,110, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 114, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,92,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
ReefAngel.PHMin=305;
ReefAngel.PHMax=995;
for (int a=0;a<SIZE(menu_items);a++)
ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a);
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit |Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.AddCustomColors();
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO(2, 120);
ReefAngel.StandardLights( Port1,11,25,17,15 );
ReefAngel.StandardLights( Port3,17,0,11,30 );
ReefAngel.WavemakerRandom1( Port5,15,45 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.StandardLights( Port7,13,0,15,30 );
if(ReefAngel.isWaterChangeMode()==1) Serial.println("In water change mode");
if(ReefAngel.isFeedingMode()==1) Serial.println("In feeding mode");
ReefAngel.LCD.BacklightOn();
ReefAngel.PWM.SetActinic( PWMSlope(11,30,17,0,11,50,60,0) );
DaylightPWMValue=PWMSlope(12,30,16,0,11,12,60,0);
CheckCloud();
char temp[]=" ";
itoa(a+1,temp,10);
ReefAngel.Portal( "CASPAR" );
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,12,60);
ReefAngel.Relay.Off( Port8 );
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<50)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=85;
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(COLOR_NAVY,255,4,16,"CL");
ReefAngel.LCD.DrawText(0,255,20,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,75,16,"Li");
ReefAngel.LCD.DrawText(0,255,95,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,44,30,"Duration");
int x=0;
if ((cloudstart/60)>=10) x=20;
else x=26;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart/60));
if ((cloudstart%60)>=10) x=38;
else x=44;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart%60));
ReefAngel.LCD.DrawText(COLOR_GREEN,255,62,40,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95;
else x=101;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113;
else x=119;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
byte x = 6;
byte y = 2;
byte t;
// Parameters
// Main Relay Box
CheckCloud();
char temp[]=" ";
itoa(a+1,temp,10);
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
DaylightPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=26;
else x=44;
int x=0;
else x=101;
else x=119;
cstart*=60;
cend*=60;
You need to place the drawCustomOutletBox on the outside of the void loop. Full corrected code is below.
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
byte x = 6;
byte y = 2;
byte t;
// Parameters
// Main Relay Box
CheckCloud();
char temp[]=" ";
itoa(a+1,temp,10);
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
DaylightPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=26;
else x=44;
int x=0;
else x=101;
else x=119;
cstart*=60;
cend*=60;
Sincerely, Brennyn
