Things to add to a custom menu
dpitalo
Post by dpitalo »
I'd like to add two items to my menu.
1. Force Cloud
2. Force Thunderstorm
but have no idea where to begin.
I attempted to follow the instructions in the PWM Module User guide with no luck.
My LED's are configured like this
3 Banks of 12 Royal Blues
2 Banks of XP-E Cool Whites
2 Banks of XP-G Cool Whites
If possible, I'd like to do a rolling cloud effect. Maybe having all the blues dim slightly and the whites on one side dim followed by the other side. The other thing that would be neat would be to just have the XP-E's for lightining and everything else just get a little dimmer.
Here's my PDE...
#define SIMPLE_MENU
#define DisplayLEDPWM
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define AutoTopOff        1
#define Actinic           2
#define Chiller           3
#define Heater            4
#define Skimmer           5
#define MetalHalide       6
#define SeaSwirl          7
#define Return            8
#define PWMRB1            0
#define PWMRB2            1
#define PWMRB3            2
#define PWMWT1            3
#define PWMWT2            4
#define PWMHN             5
byte PWMChannel[]={
  0,0,0,0,0,0};
#include <avr/pgmspace.h>
//Create the menu entries
prog_char menu1_label[] PROGMEM= "Chow Time";
prog_char menu2_label[] PROGMEM= "h2o Change";
prog_char menu3_label[] PROGMEM= "Clear ATO Warning";
prog_char menu4_label[] PROGMEM= "ph Calibration";
prog_char menu5_label[] PROGMEM= "Set Date Time";
//Group menu entries together
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.SetupCalibratePH();
void MenuEntry5()
ReefAngel.SetupDateTime();
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 6, 3, "Dave's 40g Reef");
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 14, 131, 14);
//pingSerial();
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp:        pH:");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
//pingSerial();
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
//pingSerial();
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
//pingSerial();
//Start Moon Phase Display
x += (16*4) + 8;
y += MENU_START_ROW+3;
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, 12, 55, "Moon Phase:");
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawText(20,255,81,55,"Off");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 20) ReefAngel.LCD.DrawText(20,255,81,55,"New");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 35) ReefAngel.LCD.DrawText(20,255,81,55,"Cresent");
else if(ReefAngel.PWM.GetActinicValue() >=35 && ReefAngel.PWM.GetActinicValue() < 45) ReefAngel.LCD.DrawText(20,255,81,55,"Half");
else if(ReefAngel.PWM.GetActinicValue() >=45 && ReefAngel.PWM.GetActinicValue() < 60) ReefAngel.LCD.DrawText(20,255,81,55,"Gibbous");
else if(ReefAngel.PWM.GetActinicValue() >=60 && ReefAngel.PWM.GetActinicValue() < 80) ReefAngel.LCD.DrawText(20,255,81,55,"Full");
//End Display Moon Phase Display
ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
  ReefAngel.Init();   //Initialize controller
  ReefAngel.Relay.On(Return);  //Turn Return on at startup
  ReefAngel.Relay.On(Skimmer); //Turn Skimmer on at startup
  ReefAngel.Relay.On(SeaSwirl); //Turn SeaSwirl on at startup
  ReefAngel.StandardATO(AutoTopOff,30);             //Setup AutoTopOff as Auto Top-Off function with 30s timeout
  ReefAngel.MHLights(MetalHalide,14,30,21,00,15);   //Daylight schedule 1:00pm - 9:30pm with 15min cool down
  ReefAngel.StandardLights(Actinic,13,00,21,30);    //Actinic schedule 1:00pm - 9:30pm
  ReefAngel.StandardHeater(Heater,788,792);         // Setup Heater to turn on at 78.8F and off at 79.2F
  ReefAngel.StandardFan(Chiller,797,80);             // Setup Chiller to turn on at 81.1F and off at 79.7F
    if (hour()>=21 || hour()<10)
    ReefAngel.PWM.SetActinic(0);
    //************************************************************ Start of PWM Expansion Code for Slope
  PWMChannel[PWMRB2]=PWMSlope(9,30,21,30,0,90,60,PWMChannel[PWMRB2]);                          //Royal Blue - Right Bank
  PWMChannel[PWMRB3]=PWMSlope(9,45,21,45,0,90,60,PWMChannel[PWMRB3]);                          //Royal Blue - Middle Bank
  PWMChannel[PWMRB1]=PWMSlope(10,00,22,00,0,90,60,PWMChannel[PWMRB1]);                         //Royal Blue - Left Bank
  PWMChannel[PWMWT2]=PWMSlope(11,00,21,00,0,90,90,PWMChannel[PWMWT2]);                          //XP-E Cool Whites - Left Side
  PWMChannel[PWMWT1]=PWMSlope(11,30,21,30,0,90,90,PWMChannel[PWMWT1]);                          //XP-E Cool Whites - Right Side
  PWMChannel[PWMHN]=PWMSlope(12,00,20,00,0,90,120,PWMChannel[PWMHN]);                           //XP-G Cool Whites - Left Side
      if (hour()>=21 || hour()<12)
    ReefAngel.PWM.SetDaylight(0);
    ReefAngel.PWM.SetDaylight(PWMSlope(12,30,20,30,0,90,120,ReefAngel.PWM.GetDaylightValue()));   //XP-G Cool Whites - Right Side
  for (int a=0;a<6;a++)
    ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
  //************************************************************* End of PWM Expansion Code for Slope
  ReefAngel.ShowInterface(); //Draw the Standard Interface
Re: Things to add to a custom menu
Try this:
#define SIMPLE_MENU
#define Actinic           2
#define Chiller           3
#define Heater            4
#define Skimmer           5
#define SeaSwirl          7
#define Return            8
#define PWMRB1            0
#define PWMRB2            1
#define PWMRB3            2
#define PWMWT1            3
#define PWMWT2            4
#define PWMHN             5
byte PWMChannel[]={
  0,0,0,0,0,0};
boolean ForceCloud=false;
boolean ForceLightning=false;
prog_char menu4_label[] PROGMEM= "Force Cloud";
prog_char menu5_label[] PROGMEM= "Force Lightning";
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry5()
ForceLightning=true;
byte x = 6;
byte y = 2;
byte t;
//pingSerial();
x = 12;
char text[7];
//pingSerial();
x = 10;
//pingSerial();
//pingSerial();
x += (16*4) + 8;
    CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
  // Channels used by the actinic LEDs on the PWM Expansion module
  // These channels will not be dimmed when the cloud effect is triggered
  // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000111
  // Channels used by the daylight LEDs on the PWM Expansion module
  // These channels will be used for the spike when lightning effect is triggered
  // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B111000
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (ForceCloud)
  ForceCloud=false;
  cloudchance=1;
  cloudduration=10;
//  lightningchance=1;
  cloudstart=NumMins(hour(),minute())+1;
  if (ForceLightning)
  cloudchance=1;
  cloudduration=10;
  lightningchance=1;
  if (cloudchance)
    //is it time for cloud yet?
      // let's go through all channels to pick which ones will be dimmed
        if (bitRead(Actinic_Channels,a)==0)
          // this will slope down the channel from the current PWM to 0 within 3minutes.
          // then it will stay at 0 for the duration of the cycle
          // and finally slope up from 0 to PWM value within 3 minutes
          // it is basically an inversed slope
          PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
        for (int b=0;b<6;b++)
          if (bitRead(Daylight_Channels,b)==1)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      if ((cloudstart/60)>=10) x=11; else x=17;
      if ((cloudstart%60)>=10) x=29; else x=35;
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
With this features file:
#define DateTimeSetup
#define VersionMenu
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 5
#define PWMEXPANSION
#define CUSTOM_MAIN
#define FONT_8x8
#define NUMBERS_16x16
#endif  // __REEFANGEL_FEATURES_H__
dpitalo
Post by dpitalo »
You, sir, are the man!
I'll be uploading everything as soon as I get home this evening.
dpitalo
Post by dpitalo »
Working great...it's quite cloudy on my reef today. :-)
Only thing I wish could be faster would be the lightning strikes...more of a strobe effect rather than just a couple of flashes.
That's a limitation of the driver.
I tried it too... Just doesn't discharge and charge again fast enough in my opinion.
But you can play around with this part:
            //delay(10);
            PWMChannel[b]=20;
This is where the lightning effect happens.
If you change
            PWMChannel[b]=20;
To
            PWMChannel[b]=20;
May improve things...
Or you can come up with a different logic that makes it even faster decisions.
Right now, It has to go through each channel and make a decision on whether to turn it on or off.
If the decision was made for all 6 at the same time, you may get faster response from the controller, but I don't think the driver would follow.
But who knows... I'd love to be wrong :)
