Float switches
Float switches
I'm wondering if I may have extended the cables too long. Is there a length that's to far my float swiftness show 0.
Re: Float switches
then Ill have to triple check their connections. Hmm I was kinda hoping it would be extension to far type deal since it doesnt show percentages on the portal or android app. Or is that a RA + deal?
Re: Float switches
Float switches don't have %. They are either on or off. It's a magnetic switch. When the float goes up, it closes contact. That's it. All we are looking for is closing contact. If there is a short anywhere, it would bypass the float all together, since it would always see the float as being closed.
Re: Float switches
Hi, didn't want to make a new post so I'll post in here, sorry to thread-jack. I wired my float switches to the connectors and plugged them into the correct ports. My low switch didn't work, so I tried pulling the connector out (so i could check my soldering) with a pair of needle nose pliers, and they slipped and pulled a wire out of the connector.
I noticed there's a metal tab on the connector that seems to be catching on the plastic with the purpose of holding the metal piece and wire crimp in the connector. I can push the metal tab down with a sewing needle, but I cant pull the metal crimp piece out of the connector when the tab is pushed in. Is it removable? Or do i need to buy a new connector wire?
Thanks for any help with my silly question.
-Nate
-Nate
